[Geomoose-users] Setting up first geomoose app
Brent Fraser bfraser at geoanalytic.com
Fri Jan 14 11:30:43 EST 2011
The map file should have:
  UNITS METERS
  EXTENT 41069.1 -1149.02 665378.01 1231178.57
  PROJECTION
     'init=epsg:27700'
  END
The mapbook.xml should have:
<param name="max_extent">41069.1 -1149.02 665378.01 1231178.57</param>
<param name="initial_extent">41069.1 -1149.02 665378.01 1231178.57</param>
<param name="projection">EPSG:27700</param>
and carefully follow the directions in
http://www.geomoose.org/docs/projections.html
and remove projection="EPSG:4326" from the <map-source> definition.
Do you have a specific need to use WMS or can you just use the native
mapserver protocol?
> OK, thanks, have altered all refs to read epsg:27700
> How do I enter the extent information as it seems to look nothing like the
> other entries I can find, sorry if this is a dumb question but as you can
> most likely tell this is not my normal area of work. The entries for
> extent
> that I can see in qgis are
> When imported as a shp file:
> In layer spatial reference system units : xMin,yMin 41069.1,-1149.02 :
> xMax,yMax 665378.01,1231178.57
> When imported as a wms layer
> 41069.0999999999985448,-1149.0199999999999818 :
> 665378.0000000000000000,1231180.0000000000000000
> Carl
> On Fri, Jan 14, 2011 at 3:38 PM, Brent Fraser
> <bfraser at geoanalytic.com>wrote:
>> Then I'd recommend changing all the projection references in your map
>> file
>> and mapbook to be:
>> EPSG:27700
>> since that matches the definition you gave for the data.  See
>> http://spatialreference.org/ref/epsg/27700/  for more info...
>> > Hi, Brent,
>> > I have no preferences as to the system, the files are delivered in
>> tmerc
>> > so
>> > I guess I might as well use that as then I will not have to convert
>> them
>> > should new ones become available.
>> > Carl
>> > On Fri, Jan 14, 2011 at 3:21 PM, Brent Fraser
>> >> Carl,
>> >>  You still haven't corrected the extents to match your projection.
>> >> Until
>> >> you do it won't work.
>> >> Which coordinate system do you want to use for display? longlat or
>> >> tmerc?
>> >> Brent
>> >> > Hi,
>> >> > yep sorry my error, I have altered the units to DD but am not
>> really
>> >> any
>> >> > further forward, I took a look at the data for the layers I need to
>> >> add
>> >> > and
>> >> > I think I may need to either alter the projections section in the
>> map
>> >> file
>> >> > or reproject the data.
>> >> > When I check the properties of the file in qgis I get the
>> following:
>> >> > +proj=tmerc +lat_0=49 +lon_0=-2 +k=0.9996012717 +x_0=400000
>> >> +y_0=-100000
>> >> > +ellps=airy +datum=OSGB36 +units=m +no_defs
>> >> > Luckily I only need to worry about three data files and they are
>> all
>> >> > identical in terms of the projection information I can see from the
>> >> > properties dialogue boxes in qgis.
>> >> > Does this sound reasonable?
>> >> > Cheers
>> >> > Carl
>> >> > On Fri, Jan 14, 2011 at 1:36 PM, Johan Forsman
>> <Johan.Forsman at la.gov>
>> >> > wrote:
>> >> >> The extent sections in both of your attached files are still in
>> units
>> >> >> incompatible with your chosen projection. Did you perhaps attach
>> >> >> uncorrected
>> >> >> versions?
>> >> >> You indicate units of INCHES in the MAP file but WGS84 is defined
>> by
>> >> >> decimal degrees (DD). If you are in the UK you ought to be inside
>> a
>> >> box
>> >> >> described by (-11 49 2 61), or something similar to that provided
>> I
>> >> have
>> >> >> the
>> >> >> bottom-left top-right sequence correct.
>> >> >> /Johan.
>> >> >> *From:* Carl Burn [mailto:burnsy at northcountrywoods.co.uk]
>> >> >> *Sent:* Friday, January 14, 2011 5:35 AM
>> >> >> *To:* geomoose-users at lists.sourceforge.net
>> >> >> *Subject:* Re: [Geomoose-users] Setting up first geomoose app
>> >> >> Hi, still banging up against a brick wall with this one. I have
>> taken
>> >> >> some
>> >> >> advice and resolved the extent issues in my map file and xml file.
>> I
>> >> >> have
>> >> >> also modified the map and xml files so that they are considerably
>> >> >> simpler,
>> >> >> figuring that if its simpler it will be easier to spot my
>> mistakes. I
>> >> >> have
>> >> >> attached the two files to this mail, not sure if this is allowed
>> on
>> >> the
>> >> >> listserver.
>> >> >> Here is what else I have tried:
>> >> >> 1. Ran the mapfile through shp2img and it is not generating any
>> error
>> >> >> messages at all, though the time to draw the layer comes in at
>> 0.000s
>> >> >> which
>> >> >> seems odd to me.
>> >> >> 2. Ran a get capabilities request on the map file and got the xml
>> >> back,
>> >> >> this is not reporting any errors.
>> >> >> http://www.aqua3.com:2112/cgi-bin/mapserv.exe?map=d
>> >> :\ms4w\apps\geomoose2\maps\arcview\testshp.map<
>> http://www.aqua3.com:2112/cgi-bin/mapserv.exe?map=d:%5Cms4w%5Capps%5Cgeomoose2%5Cmaps%5Carcview%5Ctestshp.map%26SERVICE%3DWMS%26VERSION%3D1.1.1%26REQUEST%3DGetMap%26LAYERS%3Dtestlayer%26STYLES%3D%26SRS%3DEPSG:4326&BBOX=-990487.465830,-31957.211592,1696934.624449,1261986.757801&WIDTH=400&HEIGHT=600&FORMAT=image/png
>> >> >> &SERVICE=WMS&VERSION=1.1.1&REQUEST=GetCapabilities
>> >> >> 3. Ran a get map request to generate a map image, again I can see
>> >> this
>> >> >> without any errors.
>> :\ms4w\apps\geomoose2\maps\arcview\testshp.map&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&LAYERS=testlayer&STYLES=&SRS=EPSG:4326&BBOX=-990487.465830,-31957.211592,1696934.624449,1261986.757801&WIDTH=400&HEIGHT=600&FORMAT=image/png<
>> >> >> 4. Connected to the wms layer with QGIS as my client, the map
>> image
>> >> >> appears
>> >> >> with no errors.
>> >> >> I am totally lost at this point and have no idea why the map image
>> is
>> >> >> not
>> >> >> appearing, any clues would be most welcome.
>> >> >> Carl
>> >> >> On Thu, Jan 13, 2011 at 9:32 PM, Brent Fraser
>> >> >> wrote:
>> >> >> And while you've got a <map-source> defined, I don't think there's
>> a
>> >> >> <Layer> set up to reference it.
>> >> >> Brent
>> >> >> > Carl,
>> >> >> > One problem is that the coordinate system is defined as longlat,
>> >> but
>> >> >> the
>> >> >> > extent is given is something other than decimal degrees:
>> >> >> >   EXTENT -990487.465830 -31957.211592 1696934.624449
>> 1261986.757801
>> >> >> >   PROJECTION
>> >> >> >      'init=epsg:4326'
>> >> >> >     'proj=longlat'
>> >> >> >     'ellps=WGS84'
>> >> >> >     'datum=WGS84'
>> >> >> >     'no_defs'
>> >> >> >   END
>> >> >> > And in the mapbook as well.
>> >> >> > Brent
>> >> >> >> Hi,
>> >> >> >> trying to get a basic app working in geomoose using our own
>> data
>> >> and
>> >> >> I
>> >> >> >> am
>> >> >> >> getting a blank map area. I have set up a simple map file in
>> the
>> >> >> >> standard
>> >> >> >> ms4w maps folder in a folder called ArcView, I have put my map
>> >> file
>> >> >> in
>> >> >> >> to
>> >> >> >> that folder and have tested it using a browser and can see a
>> map
>> >> and
>> >> >> am
>> >> >> >> able
>> >> >> >> to download an xml document when I do a get capabilities
>> request.
>> >> >> >> The map file is as follows:
>> >> >> >> ============== MAP FILE =======================
>> >> >> >> MAP
>> >> >> >>   NAME "TESTMAP"
>> >> >> >>   # Map image size
>> >> >> >>   SIZE 800 800
>> >> >> >>   UNITS INCHES
>> >> 1261986.757801
>> >> >> >>   FONTSET     "../fonts/fontset.list"
>> >> >> >>     SYMBOLSET    "../symbols/symbol.sym"
>> >> >> >>   PROJECTION
>> >> >> >>      'init=epsg:4326'
>> >> >> >>     'proj=longlat'
>> >> >> >>     'ellps=WGS84'
>> >> >> >>     'datum=WGS84'
>> >> >> >>     'no_defs'
>> >> >> >>   END
>> >> >> >>   IMAGECOLOR 255 255 255
>> >> >> >>   IMAGEQUALITY 95
>> >> >> >>   IMAGETYPE jpeg
>> >> >> >>   OUTPUTFORMAT
>> >> >> >>     NAME jpeg
>> >> >> >>     DRIVER 'GD/JPEG'
>> >> >> >>     MIMETYPE 'image/jpeg'
>> >> >> >>     IMAGEMODE RGBA
>> >> >> >>     EXTENSION 'jpeg'
>> >> >> >>   END
>> >> >> >>   LEGEND
>> >> >> >>     STATUS ON
>> >> >> >>     KEYSIZE 18 12
>> >> >> >>     LABEL
>> >> >> >>       TYPE BITMAP
>> >> >> >>       SIZE MEDIUM
>> >> >> >>       COLOR 0 0 89
>> >> >> >>     END
>> >> >> >>   END
>> >> >> >>   WEB
>> >> >> >>     IMAGEPATH '/tmp/'
>> >> >> >>     IMAGEURL '/tmp/'
>> >> >> >>     METADATA
>> >> >> >>       'ows_title'           'TESTMAP'
>> >> >> >>       'ows_onlineresource'  'http://www.*ourserver*
>> >> >> >> .com:2112/cgi-bin/mapserv.exe?map=testshp.map'
>> >> >> >>       'ows_srs'             'EPSG:4326'
>> >> >> >>     END
>> >> >> >>     TEMPLATE 'foo'
>> >> >> >>   END
>> >> >> >>   LAYER
>> >> >> >>     NAME 'RECTANGLES'
>> >> >> >>     TYPE POLYGON
>> >> >> >>     DUMP true
>> >> >> >>     TEMPLATE fooOnlyForWMSGetFeatureInfo
>> >> 1261986.757801
>> >> >> >>     DATA
>> >> 'D:/ms4w/apps/geomoose2/maps/ArcView/seamless_rectangle.shp'
>> >> >> >>     METADATA
>> >> >> >>       'ows_title' 'rectangles'
>> >> >> >>     END
>> >> >> >>     STATUS OFF
>> >> >> >>     TRANSPARENCY 100
>> >> >> >>     PROJECTION
>> >> >> >>     'init=epsg:4326'
>> >> >> >>     'proj=longlat'
>> >> >> >>     'ellps=WGS84'
>> >> >> >>     'datum=WGS84'
>> >> >> >>     'no_defs'
>> >> >> >>     END
>> >> >> >>     CLASS
>> >> >> >>        NAME 'seamless_rectangle'
>> >> >> >>        STYLE
>> >> >> >>          WIDTH 1
>> >> >> >>          OUTLINECOLOR 0 0 0
>> >> >> >>          COLOR 149 170 154
>> >> >> >>        END
>> >> >> >>     END
>> >> >> >>   END
>> >> >> >> END
>> >> >> >> =============== END OF MAP FILE=================
>> >> >> >> The map book .xml is as follows, just a commented out version
>> of
>> >> the
>> >> >> >> original one:
>> >> >> >> ============== MAPBOOK.XML ===================
>> >> >> >> <?xml version="1.0"?>
>> >> >> >> <mapbook version="2.0">
>> >> >> >>     <configuration>
>> >> >> >>             <param name="links_bar_html"><![CDATA[Perfect
>> timing
>> >> for
>> >> >> >> some
>> >> >> >> damn CDATA "all" of 'its' here <&>]]></param>
>> >> >> >>             <param
>> name="layer_controls.unfade.on">false</param>
>> >> >> >>         <!--    <param name="zoomto['Jump To:']"><![CDATA[
>> >> >> >>             'Dakota County' :
>> >> [521238.614537864,4924218.86673578,473921.947801381,4974430.36885032],
>> >> >> >>             'Parcel Data' :
>> >> >> >> [497205.409367,4923984.423582,477595.805945,4941970.52988],
>> >> >> >>             'Full State of MN' :
>> >> >> >> [189783.560000,4816309.330000,761653.524114,5472346.500000]
>> >> >> >>         ]]></param> -->
>> >> >> >>         <param
>> name="max_extent">-1053325.991731,-63036.027500,1763261.991731,1293098.927500</param>
>> >> >> >>         <param
>> name="initial_extent">-990487.465830,-31957.211592,1696934.624449,1261986.757801</param>
>> >> >> >>         <param name="layer_controls.legend.on">false</param>
>> >> >> >>         <param
>> name="mapserver_url">/cgi-bin/mapserv.exe</param>
>> >> >> >>         <param
>> >> name="mapfile_root">/ms4w/apps/geomoose2/maps/</param>
>> >> >> >>         <param name="projection">EPSG:4326</param>
>> >> >> >>         <param name="layer_controls.up.on">false</param>
>> >> >> >>         <param name="layer_controls.down.on">false</param>
>> >> >> >>         <param name="layer_controls.legend.on">true</param>
>> >> >> >>         <param name="drawing_tools.default_fill">red</param>
>> >> >> >>         <param
>> name="drawing_tools.default_stroke">yellow</param>
>> >> >> >>         <param name="drawing_tools.default_opacity">1</param>
>> >> >> >>         <param name="group_checkboxes">false</param>
>> >> >> >>         <param name="default_tab">Catalog</param>
>> >> >> >>         <param name="catalog_name">Catalog</param>
>> >> >> >>         <param
>> name="show_service_settings_in">Information</param>
>> >> >> >>         <param name="show_results_in">Information</param>
>> >> >> >>         <param name="tabs"><![CDATA[
>> >> >> >>              'Catalog' : 'catalog-tab',
>> >> >> >>              'Information' : 'information-tab',
>> >> >> >>              'Custom' : 'custom-tab'
>> >> >> >>          ]]></param>
>> >> >> >>         <param name="ground_units">km</param>
>> >> >> >>         <param
>> >> >> >> name="scales">.5,1,4,8,16,24,32,64,128,270,550,1000</param>
>> >> >> >>         <param name="reference_map.enabled">false</param>
>> >> >> >>         <param name="coordinate_display.usng">false</param>
>> >> >> >>         <param name="jumpto_scales"><![CDATA[
>> >> >> >>             '1:50000' : 50000,
>> >> >> >>             '1:24000' : 24000,
>> >> >> >>             '1:10000' : 10000,
>> >> >> >>             '1:5000' : 5000
>> >> >> >>     ]]></param>
>> >> >> >>     </configuration>
>> >> >> >>         The mapping services define the source of the mapping
>> >> data.
>> >> >> >>     <map-source name="highlight" type="mapserver">
>> >> >> >>         <file/>
>> >> >> >>         <layer name="all"/>
>> >> >> >>     </map-source>
>> >> >> >>     <map-source name="TESTMAP" type="mapserver">
>> >> >> >>         <file>./ArcView/testshp.map</file>
>> >> >> >>         <layer name="rectangles"/>
>> >> >> >>     </map-source>
>> >> >> >>     <!--    <map-source name="borders" type="mapserver"
>> >> >> >> reference="true">
>> >> >> >>         <file>./demo/statedata/basemap.map</file>
>> >> >> >>         <layer name="all"/>
>> >> >> >>     </map-source>
>> >> >> >>     <map-source name="iastate" type="wms" tiled="false"
>> >> >> >> projection="EPSG:900913" width="512" height="512">
>> >> >> >>         <url>
>> >> >> http://mesonet.agron.iastate.edu/cgi-bin/wms/nexrad/n0r.cgi
>> >> >> >> </url>
>> >> >> >>         <layer name="nexrad-n0r"/>
>> >> >> >>         <param name="format" value="image/jpeg"/>
>> >> >> >>         <param name="TRANSPARENT" value="TRUE"/>
>> >> >> >>     </map-source>
>> >> >> >>     <map-source name="metbase" type="ags" >
>> >> >> >>         <url>
>> http://gis.metc.state.mn.us/ArcGIS/rest/services/BaseLayer/UTMBaseMap/MapServer/export
>> >> >> >> </url>
>> >> >> >>         <layer name="Met Council Base Map Layers" />
>> >> >> >>         <param name="FORMAT" value="JPG"/>
>> >> >> >>     </map-source>
>> >> >> >>     <map-source name="lmic" type="wms" tiled="false">
>> >> >> >>         <url>http://geoint.lmic.state.mn.us/cgi-bin/wms</url>
>> >> >> >>         <layer name="fsa2008"/>
>> >> >> >>         <layer name="bw1997"/>
>> >> >> >>     </map-source>
>> >> >> >>     <map-source name="usgs_doq" type="wms" tiled="false"
>> >> >> >> projection='EPSG:26915'>
>> >> >> >>         <url>http://terraservice.net/ogcmap.ashx?</url>
>> >> >> >>         <layer name="DOQ"/>
>> >> >> >>     </map-source>
>> >> >> >>     <map-source name="usgs_drg" type="wms" tiled="false"
>> >> >> >>         <layer name="DRG"/>
>> >> >> >>     </map-source>
>> >> >> >>     <map-source name="reference" type="wms" tiled="false"
>> >> >> >> reference="true">
>> >> >> >>         <layer name="fsa2008" reference="true" />
>> >> >> >>     </map-source> -->
>> >> >> >>     <service name="print" title="Print Map">
>> >> >> >>         <step type="input">
>> >> >> >>             <url>php/print.php</url>
>> >> >> >>             <input type="print_info" name="layers"/>
>> >> >> >>             <input type="extent" name="extent"/>
>> >> >> >>             <input type="sketches" name="sketches"/>
>> >> >> >>             <input type="user" name="title" title="Map
>> >> >> >> Title">Map</input>
>> >> >> >>             <input type="hidden" name="date" title="Map
>> >> >> >> Date">true</input>
>> >> >> >>             <input type="select" name="template" title="Output
>> >> >> Template:
>> >> >> >>                 <option value="letter_landscape">Letter -
>> >> >> >> Landscape</option>
>> >> >> >>                 <option value="letter_portrait">Letter -
>> >> >> >> Portrait</option>
>> >> >> >>                 <option value="poster_landscape">11" x 17" -
>> >> >> >> Landscape</option>
>> >> >> >>                 <option value="poster_portrait">11" x 17" -
>> >> >> >> Portrait</option>
>> >> >> >>             </input>
>> >> >> >>             <input type="select" name="quality" title="Image
>> >> Quality:
>> >> >> >>                 <option value="2">Higher</option>
>> >> >> >>                 <option value="3">Highest</option>
>> >> >> >>                 <option value="1">Standard</option>
>> >> >> >>             </input>
>> >> >> >>             <input type="select" name="scale" title="Preserve
>> >> Scale:
>> >> >> >>                 <option value="preserve">Yes</option>
>> >> >> >>                 <option value="no">No</option>
>> >> >> >>             </input>
>> >> >> >>         </step>
>> >> >> >>     </service>
>> >> >> >>     <service name="identify" title="Identify" display="false">
>> >> >> >>         <url>php/identify.php</url>
>> >> >> >>         <step type="spatial" name="shape" line="false"
>> >> >> polygon="false"
>> >> >> >> jump-start="true" default="point">
>> >> >> >>             <input type="visiblelayers" name="layers"/>
>> >> >> >>         </step>
>> >> >> >>     </service>
>> >> >> >>     <service name="birdseye" display="false" target="_blank">
>> >> >> >>         <url>php/birdseye.php</url>
>> >> >> >>         <step type="spatial" name="xy" line="false"
>> >> polygon="false"
>> >> >> >> jump-start="true" default="point" format="delim"
>> >> >> reproject="EPSG:4326">
>> >> >> >>         </step>
>> >> >> >>     </service>
>> >> >> >>     <service name="streetview" display="false" target="_blank">
>> >> >> >>         <url>php/streetview.php</url>
>> >> polygon="false"
>> >> >> >>         </step>
>> >> >> >>     </service>
>> >> >> >>     <service name="feature_report" display="false">
>> >> >> >>         <url>php/feature_report.php</url>
>> >> >> >>         <input type="hidden" name="layers" value="lmic/fsa"/>
>> >> >> >>         <input type="hidden" name="src"/>
>> >> >> >>         <input type="hidden" name="PIN"/>
>> >> >> >>     </service>
>> >> >> >>     <service name="select" title="Select">
>> >> >> >>         <url>php/select.php</url>
>> >> >> >>         <!-- Send a selection shape + the visible layers list
>> to
>> >> the
>> >> >> >> service
>> >> >> >>         <step type="spatial" showTools="true" name="shape"
>> >> >> line="true"
>> >> >> >> polygon="true" point="true" default="polygon"
>> edit-polygon="false"
>> >> >> >> pan="false" jump-start="true">
>> >> >> >>             <header><![CDATA[Create a selection area by
>> clicking
>> >> on
>> >> >> the
>> >> >> >> map.]]></header>
>> >> >> >>                 Option values should be the mapbook path to the
>> >> >> layer.
>> >> >> >>                 This only supports 'mapserver'-type layers.
>> >> >> >>             <input type="select" name="select_layer"
>> >> title="Select:">
>> >> >> >>                 <option
>> value="parcels/parcels">Parcels</option>
>> >> >> >>             </input>
>> >> >> >>             <input type="user" name="shape_buffer"
>> title="Buffer
>> >> >> >> Selection
>> >> >> >> Shape (ft)">0</input>
>> >> >> >>             <input type="select" name="query_layer"
>> title="Using
>> >> >> >> Features
>> >> >> >> In">
>> >> >> >>                 <option
>> >> >> >>             </input>
>> title="Buffer
>> >> >> >> Selection
>> >> >> >>             <footnote><![CDATA[
>> >> >> >>             ]]></footnote>
>> >> >> >>         </step>
>> >> >> >>     </service>
>> >> >> >>     <!-- this is called after a standard select in order to
>> buffer
>> >> >> the
>> >> >> >> previous selection -->
>> >> >> >>     <service name="buffered_select_followup" title="Buffered
>> >> Select">
>> >> >> >>         <step type="input">
>> >> >> >>             <input type="hidden" name="shape"/>
>> >> >> >>             <input type="hidden" name="select_layer"/>
>> >> >> >>             <input type="hidden" name="query_layer"/>
>> >> >> >>             <input type="hidden" name="shape_buffer"/>
>> >> >> >>             <input type="user" name="selection_buffer"
>> >> title="Buffer
>> >> >> >> Features By: "/>
>> >> >> >>         </step>
>> >> >> >>     </service>
>> >> >> >>     <service name="buffered_select" title="Buffered Select">
>> to
>> >> the
>> >> >> >> service
>> >> >> line="true"
>> >> >> >> pan="false">
>> clicking
>> >> on
>> >> >> the
>> >> >> >> map.]]></header>
>> >> >> layer.
>> title="Select
>> >> >> >> features
>> >> >> >> from:">
>> >> >> >>                 <option
>> >> >> >>             </input>
>> >> title="Buffer
>> >> >> >> Selected Features (ft)">0</input>
>> >> >> >> <!--            <input type="user" name="shape_buffer"
>> >> title="Buffer
>> >> >> >> Selection Shape (ft)">0</input>
>> title="Using
>> >> >> >> Features
>> >> >> >> In">
>> >> >> >>                 <option
>> >> >> >>             </input>
>> >> >> >>             <footnote><![CDATA[
>> >> >> >>             ]]></footnote>
>> >> >> >>         </step>
>> >> >> >>     </service>
>> >> >> >>     <service name="popups" display="false">
>> >> >> >>         <url>php/popups.php</url>
>> >> >> polygon="false"
>> >> >> >>             <header><![CDATA[
>> >> >> >>             Click on the map to show a popup about the
>> features.
>> >> >> >>             ]]></header>
>> >> >> >>             <input type="hidden" name="layer"/>
>> >> >> >>         </step>
>> >> >> >>     </service>
>> >> >> >>     <service name="geocode_address" title="Geocode Address">
>> >> >> >>         <url>php/geocode.php</url>
>> >> >> >>         <step type="input">
>> >> >> >>             <input type="user" name="address" title="Enter
>> >> Address:
>> >> >> >>             <input type="hidden" name="googlekey"
>> value="ABQIAAAA4Q-VLyIpwp3L8M9DIzKb2BT2yXp_ZAY8_ufC3CFXhHIE1NvwkxRe8Hd6FR51Hvb-Fvd-wGjiDZDC4w"/>
>> >> >> >>         </step>
>> >> >> >>     </service>
>> >> >> >>     <service name="search_parcels">
>> >> >> >>         <url>php/query.php</url>
>> >> >> >>         <step type="input">
>> >> >> >>             <input type="hidden" name="highlight"
>> value="true"/>
>> >> >> >>             <input type="hidden" name="mode" value="search"/>
>> >> >> >>             <input type="hidden" name="layer0"
>> >> >> value="parcels/parcels"/>
>> >> >> >>             <input type="hidden" name="template0"
>> >> value="itemquery"/>
>> >> >> >>             <input type="select" name="fieldname0"
>> title="Search
>> >> >> By:">
>> >> >> >>                 <option value="OWNER_NAME">Owner</option>
>> >> >> >>                 <option value="PIN">Parcel ID</option>
>> >> >> >>             </input>
>> >> >> >>             <input type="select" name="comparitor0"
>> title="That:
>> >> >> >>                 <option value="like-icase">Contains</option>
>> >> >> >>                 <option value="right-like-icase">Begins
>> >> With</option>
>> >> >> >>                 <option value="eq-str">Matches Exactly</option>
>> >> >> >>             </input>
>> >> >> >>             <input type="user" name="value0" title=""/>
>> >> >> >>             <input type="hidden" name="fieldname1"
>> >> >> value="FIN_SQ_FT"/>
>> >> >> >>             <input type="select" name="operator1">
>> >> >> >>                 <option value="or">OR</option>
>> >> >> >>                 <option value="and">AND</option>
>> >> >> >>             </input>
>> >> >> >>             <input type="select" name="comparitor1"
>> title="Having
>> >> >> Fin.
>> >> >> >> Sq.
>> >> >> >> Ft. ">
>> >> >> >>                 <option value="gt">Greater Than</option>
>> >> >> >>                 <option value="eq">Equal To</option>
>> >> >> >>                 <option value="lt">Less Than</option>
>> >> >> >>             </input>
>> >> >> >>             <input type="user" name="value1" title=""/>
>> >> >> >>         </step>
>> >> >> >>     </service>
>> >> >> >>         The catalog defines how the layers will be displayed in
>> >> the
>> >> >> >> catalog
>> >> >> >> tab.
>> >> >> >>     <layer-controls>
>> >> >> >>         <layer-control name="popups" service-name="popups"
>> >> >> >> layer-input="layer" on="false" tip="Show Popups for %LAYER%"/>
>> >> >> >>     </layer-controls>
>> >> >> >>     <catalog>
>> >> >> >>     <!--     <layer title="overallmap" src="parcels/parcels"
>> >> >> status="on"
>> >> >> >> popups="true" minscale="0" maxscale="150000" metadata="true" >
>> >> >> >>             <metadata>http://www.aqua3.com</metadata>
>> >> >> >>         </layer>
>> >> >> >>         <layer title="City and County Boundaries"
>> >> src="borders/all"
>> >> >> >> status="on"/>
>> >> >> >>         <layer title="Weather Radar" src="iastate/nexrad-n0r"
>> >> >> >> status="off"
>> >> >> >> legend="false"/>
>> >> >> >>         <group title="Backgrounds" expand="true"
>> multiple="false">
>> >> >> >>             <layer title="Metro Base Map" src="metbase/Met
>> Council
>> >> >> Base
>> >> >> >> Map
>> >> >> >> Layers" status="on" legend="false" />
>> >> >> >>             <layer title="2008 Aerial Photographs"
>> >> src="lmic/fsa2008"
>> >> >> >> status="off" legend="false" />
>> >> >> >>             <layer title="1997 Aerial Photographs"
>> >> src="lmic/bw1997"
>> >> >> >>             <layer title="USGS DOQs" src="usgs_doq/DOQ"
>> >> status="off"
>> >> >> >> fade="true" unfade="true" legend="false" />
>> >> >> >>             <layer title="USGS Topo Quads" src="usgs_drg/DRG"
>> >> >> >> status="off"
>> >> >> >>             <layer title="None" src=" " status="off"
>> >> legend="false"
>> >> >> >> fade="false" unfade="false" />
>> >> >> >>         </group> -->
>> >> >> >>     </catalog>
>> >> >> >>         The toolbar defines which services are referneces in
>> the
>> >> >> toolbar
>> >> >> >>     <toolbar>
>> >> >> >>         <tool name="previous" title="Previous Extent"
>> >> type="internal"
>> >> >> >> action="previous" selectable="false"/>
>> >> >> >>         <tool name="next" title="Next Extent" type="internal"
>> >> >> >> action="next"
>> >> >> >>         <tool name="fullextent" title="Zoom to Full Extent"
>> >> >> >> type="internal"
>> >> >> >> action="fullextent" selectable="false"/>
>> >> >> >>         <tool name="pan" title="Pan" type="internal"
>> >> action="pan"/>
>> >> >> >>         <tool name="zoomin" title="Zoom In" type="internal"
>> >> >> >> action="zoomin"
>> >> >> >> selected="true"/>
>> >> >> >>         <tool name="zoomout" title="Zoom Out" type="internal"
>> >> >> >> action="zoomout"/>
>> >> >> >>         <!--    <tool name="identify" title="Identify"
>> >> type="service"
>> >> >> >> service="identify" cursor="url('cursors/identify2.cur') 9
>> >> >> >> 9,url('cursors/identify2.cur'),auto" /> -->
>> >> >> >> <!--        <tool name="select" title="Select" type="service"
>> >> >> >> service="select"/> -->
>> >> >> >>         <!--    <tool name="buffered_select" title="Buffered
>> >> Select"
>> >> >> >> type="service" service="buffered_select"/> -->
>> >> >> >>         <!--    <tool name="clear" title="Clear Selection"
>> >> >> >> type="javascript"
>> >> >> >> selectable="false">
>> >> >> >>             GeoMOOSE.changeLayerVisibility('highlight/all',
>> >> false);
>> >> >> >>         </tool> -->
>> >> >> >>         <tool name="measure" title="Measure" type="internal"
>> >> >> >> action="measure"/>
>> >> >> >>         <tool name="measurearea" title="Measure Area"
>> >> type="internal"
>> >> >> >> action="measurearea"/>
>> >> >> >>         <!-- <tool name="search_parcels" title="Search Parcels"
>> >> >> >> type="service" service="search_parcels" selectable="false"/>
>> >> >> >>         <!-- <tool name="print" title="Print" type="service"
>> >> >> >> service="print"
>> >> >> >> selectable="false"/> -->
>> >> >> >>         <!-- <tool name="birdseye" title="Bird's Eye View"
>> >> >> >> type="service"
>> >> >> >> selectable="true" service="birdseye"/> -->
>> >> >> >>         <!-- <tool name="streetview" title="Google Street View"
>> >> >> >> type="service" service="streetview" selectable="true"/> -->
>> >> >> >>         <!-- <tool name="geocode" title="Geocode Address"
>> >> >> type="service"
>> >> >> >> service="geocode_address" selectable="true"/>  -->
>> >> >> >>         <!-- <drawer>
>> >> >> >>             <tool name="markup_tools" title="Sketch Tools"
>> >> >> >> type="internal"
>> >> >> >> action="none" selectable="false"/>
>> >> >> >>             <tool name="draw_polygon" title="Draw Polygon"
>> >> >> >> type="internal"
>> >> >> >> action="draw_polygon"/>
>> >> >> >>             <tool name="draw_line" title="Draw Line"
>> >> type="internal"
>> >> >> >> action="draw_line"/>
>> >> >> >>             <tool name="draw_point" title="Draw Point"
>> >> >> type="internal"
>> >> >> >> action="draw_point"/>
>> >> >> >>             <tool name="draw_remove" title="Remove Drawing"
>> >> >> >> type="internal"
>> >> >> >> action="draw_remove"/>
>> >> >> >>             <tool name="draw_edit" title="Edit Drawing"
>> >> >> type="internal"
>> >> >> >> action="draw_edit_shapes"/>
>> >> >> >>             <tool name="draw_edit_attributes" title="Edit
>> >> Attributes"
>> >> >> >> type="internal" action="draw_edit_attributes"/>
>> >> >> >>             <tool name="clear_drawings" title="Clear Drawings"
>> >> >> >> type="internal" action="clear_drawings" selectable="false"/>
>> >> >> >>         </drawer> -->
>> >> >> >>     </toolbar>
>> >> >> >> </mapbook>
>> >> >> >> ============= END OF MAPBOOK.XML =============
>> >> >> >> I have tried getting some error reporting out of firebug with
>> >> little
>> >> >> >> success, if anyone can help me spot what I have done wrong it
>> >> would
>> >> >> be
>> >> >> >> much
>> >> >> >> appreciated and I would be happy to supply the real url's to
>> the
>> >> >> server
>> >> >> >> off-list.
>> >> >> >> Cheers
>> >> >> >> Carl
>> >> >> >> Protect Your Site and Customers from Malware Attacks
>> >> >> >> Learn about various malware tactics and how to avoid them.
>> >> Understand
>> >> >> >> malware threats, the impact they can have on your business, and
>> >> how
>> >> >> you
>> >> >> >> can protect your company and customers by using code signing.
>> http://p.sf.net/sfu/oracle-sfdevnl_______________________________________________
>> >> >> >> Geomoose-users mailing list
>> >> >> >> Geomoose-users at lists.sourceforge.net
>> >> >> >> https://lists.sourceforge.net/lists/listinfo/geomoose-users
>> >> >> > Best Regards
>> >> >> > Brent Fraser
>> >> Understand
>> how
>> >> >> you
>> >> >> Best Regards
>> >> >> Brent Fraser
>> Understand
>> >> > malware threats, the impact they can have on your business, and how
>> >> you
>> >> Best Regards
>> >> Brent Fraser
>> > Learn about various malware tactics and how to avoid them. Understand
>> you
>> Best Regards
>> Brent Fraser
Best Regards
Brent Fraser
More information about the Geomoose-users mailing list
