[Geomoose-users] Setting up first geomoose app
Brian Fischer bfischer at houstoneng.com
Fri Jan 14 14:04:48 EST 2011
The challenge with doing everything with this is some of the PHP services are not written to work with WMS/WFS.  For example the Buffer, Select, and Attribute search services only work with MapServer type layers so if you need those keep that in mind.  It's not that they couldn't work with WMS/WFS but it would take some work.  I also for the clients I work with I don't think they would be satisfied with the performance of WFS.
If you are just rendering map layers and doing identify then it works good.
Just wanted to make sure everyone was aware of this and keep that in mind.
Brian Fischer, CFM  GIS Manager
Houston Engineering, Inc.
Phone: Direct: 763-493-6664 / W: 763.493.4522 / M: 763.229.2734
-----Original Message-----
From: Brent Fraser [mailto:bfraser at geoanalytic.com]
Sent: Friday, January 14, 2011 11:22 AM
To: Bob Basques
Cc: geomoose-users at lists.sourceforge.net
Subject: Re: [Geomoose-users] Setting up first geomoose app
I agree with Bob; it's better to go with a standard.  But for the purposes of resolving config problems, I like to use the mapserver protocol (it's better supported/tested in GeoMoose).  Once things are working, switching to WMS has excellent benefits.
And I think for future releases of GeoMoose we should concentrate on WMS,WFS as the "standard" protocol for the demos etc.
Brent
> All,
> I've been following the thread (any keeping quiet in order to not
> confuse
> things) and would like to add in my 2cents on the WMS angle.  I
> (we've) been going the route of providing everything in a WMS that we
> publish as a standard, and it's paid off very well with regard to
> interoperability issues.
> We use WMS in AutoCAD, ESRI, QGIS, Google Earth to name a few.  Having
> the WMS allow much more flexibilty with regard to distribution of the data.
> While you don't need the data to be in a WMS form for GeoMoose, I
> would advise that you set up your services with WMS (and WFS) in mind
> to eventually be serverd.
> Ok, I'm done . . . .
> bobb
>>>> Carl Burn <burnsy at northcountrywoods.co.uk> wrote:
> Hi,
> I will get right on it, I have been asked if it can be done using wms
> - though I am not sure why, things sometimes take a while to filter
> down to my level ;-)
> The main aim is simply to get it working and showing maps which
> hopefully I can go ahead and resolve now, once again thanks for your help.
> Carl
> On Fri, Jan 14, 2011 at 4:30 PM, Brent Fraser
> <bfraser at geoanalytic.com>
> wrote:
> The map file should have:
> UNITS METERS
> EXTENT 41069.1 -1149.02 665378.01 1231178.57 PROJECTION
> 'init=epsg:27700'
> END
> The mapbook.xml should have:
> <param name="max_extent">41069.1 -1149.02 665378.01 1231178.57</param>
> <param name="initial_extent">41069.1 -1149.02 665378.01
> 1231178.57</param> <param name="projection">EPSG:27700</param>
> and carefully follow the directions in
> http://www.geomoose.org/docs/projections.html
> and remove projection="EPSG:4326" from the <map-source> definition.
> Do you have a specific need to use WMS or can you just use the native
> mapserver protocol?
>> OK, thanks, have altered all refs to read epsg:27700
>> How do I enter the extent information as it seems to look nothing
>> like the other entries I can find, sorry if this is a dumb question
>> but as you can most likely tell this is not my normal area of work.
>> The entries for extent that I can see in qgis are
>> When imported as a shp file:
>> In layer spatial reference system units : xMin,yMin 41069.1,-1149.02 :
>> xMax,yMax 665378.01,1231178.57
>> When imported as a wms layer
>> 41069.0999999999985448,-1149.0199999999999818 :
>> 665378.0000000000000000,1231180.0000000000000000
>> Carl
>> On Fri, Jan 14, 2011 at 3:38 PM, Brent Fraser
>> <bfraser at geoanalytic.com>wrote:
>>> Then I'd recommend changing all the projection references in your
>>> map file and mapbook to be:
>>> EPSG:27700
>>> since that matches the definition you gave for the data. See
>>> http://spatialreference.org/ref/epsg/27700/ for more info...
>>> > Hi, Brent,
>>> > I have no preferences as to the system, the files are delivered in
>>> tmerc
>>> > so
>>> > I guess I might as well use that as then I will not have to
>>> > convert
>>> them
>>> > should new ones become available.
>>> > Carl
>>> > On Fri, Jan 14, 2011 at 3:21 PM, Brent Fraser
>>> >> Carl,
>>> >> You still haven't corrected the extents to match your projection.
>>> >> Until
>>> >> you do it won't work.
>>> >> Which coordinate system do you want to use for display? longlat
>>> >> or tmerc?
>>> >> Brent
>>> >> > Hi,
>>> >> > yep sorry my error, I have altered the units to DD but am not
>>> really
>>> >> any
>>> >> > further forward, I took a look at the data for the layers I
>>> >> > need
>>> to
>>> >> add
>>> >> > and
>>> >> > I think I may need to either alter the projections section in
>>> >> > the
>>> map
>>> >> file
>>> >> > or reproject the data.
>>> >> > When I check the properties of the file in qgis I get the
>>> following:
>>> >> > +proj=tmerc +lat_0=49 +lon_0=-2 +k=0.9996012717 +x_0=400000
>>> >> +y_0=-100000
>>> >> > +ellps=airy +datum=OSGB36 +units=m +no_defs
>>> >> > Luckily I only need to worry about three data files and they
>>> >> > are
>>> all
>>> >> > identical in terms of the projection information I can see from
>>> the
>>> >> > properties dialogue boxes in qgis.
>>> >> > Does this sound reasonable?
>>> >> > Cheers
>>> >> > Carl
>>> >> > On Fri, Jan 14, 2011 at 1:36 PM, Johan Forsman
>>> <Johan.Forsman at la.gov>
>>> >> > wrote:
>>> >> >> The extent sections in both of your attached files are still
>>> >> >> in
>>> units
>>> >> >> incompatible with your chosen projection. Did you perhaps
>>> >> >> attach uncorrected versions?
>>> >> >> You indicate units of INCHES in the MAP file but WGS84 is
>>> >> >> defined
>>> by
>>> >> >> decimal degrees (DD). If you are in the UK you ought to be
>>> >> >> inside
>>> a
>>> >> box
>>> >> >> described by (-11 49 2 61), or something similar to that
>>> >> >> provided
>>> I
>>> >> have
>>> >> >> the
>>> >> >> bottom-left top-right sequence correct.
>>> >> >> /Johan.
>>> >> >> *From:* Carl Burn [mailto:burnsy at northcountrywoods.co.uk]
>>> >> >> *Sent:* Friday, January 14, 2011 5:35 AM
>>> >> >> *To:* geomoose-users at lists.sourceforge.net
>>> >> >> *Subject:* Re: [Geomoose-users] Setting up first geomoose app
>>> >> >> Hi, still banging up against a brick wall with this one. I
>>> >> >> have
>>> taken
>>> >> >> some
>>> >> >> advice and resolved the extent issues in my map file and xml
>>> file.
>>> I
>>> >> >> have
>>> >> >> also modified the map and xml files so that they are
>>> >> >> considerably simpler, figuring that if its simpler it will be
>>> >> >> easier to spot my
>>> mistakes. I
>>> >> >> have
>>> >> >> attached the two files to this mail, not sure if this is
>>> >> >> allowed
>>> on
>>> >> the
>>> >> >> listserver.
>>> >> >> Here is what else I have tried:
>>> >> >> 1. Ran the mapfile through shp2img and it is not generating
>>> >> >> any
>>> error
>>> >> >> messages at all, though the time to draw the layer comes in at
>>> 0.000s
>>> >> >> which
>>> >> >> seems odd to me.
>>> >> >> 2. Ran a get capabilities request on the map file and got the
>>> >> >> xml
>>> >> back,
>>> >> >> this is not reporting any errors.
>>> >> >> http://www.aqua3.com:2112/cgi-bin/mapserv.exe?map=d
>>> >> :\ms4w\apps\geomoose2\maps\arcview\testshp.map<
>>> http://www.aqua3.com:2112/cgi-bin/mapserv.exe?map=d:%5Cms4w%5Capps%5
>>> Cgeomoose2%5Cmaps%5Carcview%5Ctestshp.map%26SERVICE%3DWMS%26VERSION%
>>> 3D1.1.1%26REQUEST%3DGetMap%26LAYERS%3Dtestlayer%26STYLES%3D%26SRS%3D
>>> EPSG:4326&BBOX=-990487.465830,-31957.211592,1696934.624449,1261986.7
>>> 57801&WIDTH=400&HEIGHT=600&FORMAT=image/png
>>> >> >> &SERVICE=WMS&VERSION=1.1.1&REQUEST=GetCapabilities
>>> >> >> 3. Ran a get map request to generate a map image, again I can
>>> >> >> see
>>> >> this
>>> >> >> without any errors.
>>> :\ms4w\apps\geomoose2\maps\arcview\testshp.map&SERVICE=WMS&VERSION=1
>>> .1.1&REQUEST=GetMap&LAYERS=testlayer&STYLES=&SRS=EPSG:4326&BBOX=-990
>>> 487.465830,-31957.211592,1696934.624449,1261986.757801&WIDTH=400&HEI
>>> GHT=600&FORMAT=image/png<
>>> >> >> 4. Connected to the wms layer with QGIS as my client, the map
>>> image
>>> >> >> appears
>>> >> >> with no errors.
>>> >> >> I am totally lost at this point and have no idea why the map
>>> image
>>> is
>>> >> >> not
>>> >> >> appearing, any clues would be most welcome.
>>> >> >> Carl
>>> >> >> On Thu, Jan 13, 2011 at 9:32 PM, Brent Fraser
>>> >> >> wrote:
>>> >> >> And while you've got a <map-source> defined, I don't think
>>> there's
>>> a
>>> >> >> <Layer> set up to reference it.
>>> >> >> Brent
>>> >> >> > Carl,
>>> >> >> > One problem is that the coordinate system is defined as
>>> longlat,
>>> >> but
>>> >> >> the
>>> >> >> > extent is given is something other than decimal degrees:
>>> >> >> > EXTENT -990487.465830 -31957.211592 1696934.624449
>>> 1261986.757801
>>> >> >> > PROJECTION
>>> >> >> > 'init=epsg:4326'
>>> >> >> > 'proj=longlat'
>>> >> >> > 'ellps=WGS84'
>>> >> >> > 'datum=WGS84'
>>> >> >> > 'no_defs'
>>> >> >> > END
>>> >> >> > And in the mapbook as well.
>>> >> >> > Brent
>>> >> >> >> Hi,
>>> >> >> >> trying to get a basic app working in geomoose using our own
>>> data
>>> >> and
>>> >> >> I
>>> >> >> >> am
>>> >> >> >> getting a blank map area. I have set up a simple map file
>>> >> >> >> in
>>> the
>>> >> >> >> standard
>>> >> >> >> ms4w maps folder in a folder called ArcView, I have put my
>>> >> >> >> map
>>> >> file
>>> >> >> in
>>> >> >> >> to
>>> >> >> >> that folder and have tested it using a browser and can see
>>> >> >> >> a
>>> map
>>> >> and
>>> >> >> am
>>> >> >> >> able
>>> >> >> >> to download an xml document when I do a get capabilities
>>> request.
>>> >> >> >> The map file is as follows:
>>> >> >> >> ============== MAP FILE =======================
>>> >> >> >> MAP
>>> >> >> >> NAME "TESTMAP"
>>> >> >> >> # Map image size
>>> >> >> >> SIZE 800 800
>>> >> >> >> UNITS INCHES
>>> >> 1261986.757801
>>> >> >> >> FONTSET "../fonts/fontset.list"
>>> >> >> >> SYMBOLSET "../symbols/symbol.sym"
>>> >> >> >> PROJECTION
>>> >> >> >> 'init=epsg:4326'
>>> >> >> >> 'proj=longlat'
>>> >> >> >> 'ellps=WGS84'
>>> >> >> >> 'datum=WGS84'
>>> >> >> >> 'no_defs'
>>> >> >> >> END
>>> >> >> >> IMAGECOLOR 255 255 255
>>> >> >> >> IMAGEQUALITY 95
>>> >> >> >> IMAGETYPE jpeg
>>> >> >> >> OUTPUTFORMAT
>>> >> >> >> NAME jpeg
>>> >> >> >> DRIVER 'GD/JPEG'
>>> >> >> >> MIMETYPE 'image/jpeg'
>>> >> >> >> IMAGEMODE RGBA
>>> >> >> >> EXTENSION 'jpeg'
>>> >> >> >> END
>>> >> >> >> LEGEND
>>> >> >> >> STATUS ON
>>> >> >> >> KEYSIZE 18 12
>>> >> >> >> LABEL
>>> >> >> >> TYPE BITMAP
>>> >> >> >> SIZE MEDIUM
>>> >> >> >> COLOR 0 0 89
>>> >> >> >> END
>>> >> >> >> END
>>> >> >> >> WEB
>>> >> >> >> IMAGEPATH '/tmp/'
>>> >> >> >> IMAGEURL '/tmp/'
>>> >> >> >> METADATA
>>> >> >> >> 'ows_title' 'TESTMAP'
>>> >> >> >> 'ows_onlineresource' 'http://www.*ourserver*
>>> >> >> >> .com:2112/cgi-bin/mapserv.exe?map=testshp.map'
>>> >> >> >> 'ows_srs' 'EPSG:4326'
>>> >> >> >> END
>>> >> >> >> TEMPLATE 'foo'
>>> >> >> >> END
>>> >> >> >> LAYER
>>> >> >> >> NAME 'RECTANGLES'
>>> >> >> >> TYPE POLYGON
>>> >> >> >> DUMP true
>>> >> >> >> TEMPLATE fooOnlyForWMSGetFeatureInfo EXTENT -990487.465830
>>> >> 1261986.757801
>>> >> >> >> DATA
>>> >> 'D:/ms4w/apps/geomoose2/maps/ArcView/seamless_rectangle.shp'
>>> >> >> >> METADATA
>>> >> >> >> 'ows_title' 'rectangles'
>>> >> >> >> END
>>> >> >> >> STATUS OFF
>>> >> >> >> TRANSPARENCY 100
>>> >> >> >> PROJECTION
>>> >> >> >> 'init=epsg:4326'
>>> >> >> >> 'proj=longlat'
>>> >> >> >> 'ellps=WGS84'
>>> >> >> >> 'datum=WGS84'
>>> >> >> >> 'no_defs'
>>> >> >> >> END
>>> >> >> >> CLASS
>>> >> >> >> NAME 'seamless_rectangle'
>>> >> >> >> STYLE
>>> >> >> >> WIDTH 1
>>> >> >> >> OUTLINECOLOR 0 0 0
>>> >> >> >> COLOR 149 170 154
>>> >> >> >> END
>>> >> >> >> END
>>> >> >> >> END
>>> >> >> >> END
>>> >> >> >> =============== END OF MAP FILE=================
>>> >> >> >> The map book .xml is as follows, just a commented out
>>> >> >> >> version
>>> of
>>> >> the
>>> >> >> >> original one:
>>> >> >> >> ============== MAPBOOK.XML =================== <?xml
>>> >> >> >> version="1.0"?> <mapbook version="2.0"> <configuration>
>>> >> >> >> <param name="links_bar_html"><![CDATA[Perfect
>>> timing
>>> >> for
>>> >> >> >> some
>>> >> >> >> damn CDATA "all" of 'its' here <&>]]></param> <param
>>> name="layer_controls.unfade.on">false</param>
>>> >> >> >> <!-- <param name="zoomto['Jump To:']"><![CDATA[ { 'Dakota
>>> >> >> >> County' :
>>> >> [521238.614537864,4924218.86673578,473921.947801381,4974430.36885
>>> >> 032],
>>> >> >> >> 'Parcel Data' :
>>> >> >> >> [497205.409367,4923984.423582,477595.805945,4941970.52988],
>>> >> >> >> 'Full State of MN' :
>>> >> >> >> [189783.560000,4816309.330000,761653.524114,5472346.500000]
>>> >> >> >> ]]></param> -->
>>> >> >> >> <param
>>> name="max_extent">-1053325.991731,-63036.027500,1763261.991731,12930
>>> 98.927500</param>
>>> >> >> >> <param
>>> name="initial_extent">-990487.465830,-31957.211592,1696934.624449,12
>>> 61986.757801</param>
>>> >> >> >> <param name="layer_controls.legend.on">false</param>
>>> >> >> >> <param
>>> name="mapserver_url">/cgi-bin/mapserv.exe</param>
>>> >> >> >> <param
>>> >> name="mapfile_root">/ms4w/apps/geomoose2/maps/</param>
>>> >> >> >> <param name="projection">EPSG:4326</param>
>>> >> >> >> <param name="layer_controls.up.on">false</param>
>>> >> >> >> <param name="layer_controls.down.on">false</param>
>>> >> >> >> <param name="layer_controls.legend.on">true</param>
>>> >> >> >> <param name="drawing_tools.default_fill">red</param>
>>> >> >> >> <param
>>> name="drawing_tools.default_stroke">yellow</param>
>>> >> >> >> <param name="drawing_tools.default_opacity">1</param>
>>> >> >> >> <param name="group_checkboxes">false</param>
>>> >> >> >> <param name="default_tab">Catalog</param>
>>> >> >> >> <param name="catalog_name">Catalog</param>
>>> >> >> >> <param
>>> name="show_service_settings_in">Information</param>
>>> >> >> >> <param name="show_results_in">Information</param>
>>> >> >> >> <param name="tabs"><![CDATA[ { 'Catalog' : 'catalog-tab',
>>> >> >> >> 'Information' : 'information-tab', 'Custom' : 'custom-tab'
>>> >> >> >> ]]></param>
>>> >> >> >> <param name="ground_units">km</param> <param
>>> >> >> >> name="scales">.5,1,4,8,16,24,32,64,128,270,550,1000</param>
>>> >> >> >> <param name="reference_map.enabled">false</param>
>>> >> >> >> <param name="coordinate_display.usng">false</param>
>>> >> >> >> <param name="jumpto_scales"><![CDATA[ { '1:50000' : 50000,
>>> >> >> >> '1:24000' : 24000, '1:10000' : 10000, '1:5000' : 5000 }
>>> >> >> >> ]]></param>
>>> >> >> >> </configuration>
>>> >> >> >> The mapping services define the source of the mapping
>>> >> data.
>>> >> >> >> <map-source name="highlight" type="mapserver"> <file/>
>>> >> >> >> <layer name="all"/> </map-source>
>>> >> >> >> <map-source name="TESTMAP" type="mapserver">
>>> >> >> >> <file>./ArcView/testshp.map</file>
>>> >> >> >> <layer name="rectangles"/>
>>> >> >> >> </map-source>
>>> >> >> >> <!-- <map-source name="borders" type="mapserver"
>>> >> >> >> reference="true">
>>> >> >> >> <file>./demo/statedata/basemap.map</file>
>>> >> >> >> <layer name="all"/>
>>> >> >> >> </map-source>
>>> >> >> >> <map-source name="iastate" type="wms" tiled="false"
>>> >> >> >> projection="EPSG:900913" width="512" height="512"> <url>
>>> >> >> http://mesonet.agron.iastate.edu/cgi-bin/wms/nexrad/n0r.cgi
>>> >> >> >> </url>
>>> >> >> >> <layer name="nexrad-n0r"/>
>>> >> >> >> <param name="format" value="image/jpeg"/> <param
>>> >> >> >> name="TRANSPARENT" value="TRUE"/> </map-source>
>>> >> >> >> <map-source name="metbase" type="ags" > <url>
>>> http://gis.metc.state.mn.us/ArcGIS/rest/services/BaseLayer/UTMBaseMa
>>> p/MapServer/export
>>> >> >> >> </url>
>>> >> >> >> <layer name="Met Council Base Map Layers" /> <param
>>> >> >> >> name="FORMAT" value="JPG"/> </map-source>
>>> >> >> >> <map-source name="lmic" type="wms" tiled="false">
>>> >> >> >> <url>http://geoint.lmic.state.mn.us/cgi-bin/wms</url>
>>> >> >> >> <layer name="fsa2008"/>
>>> >> >> >> <layer name="bw1997"/>
>>> >> >> >> </map-source>
>>> >> >> >> <map-source name="usgs_doq" type="wms" tiled="false"
>>> >> >> >> projection='EPSG:26915'>
>>> >> >> >> <url>http://terraservice.net/ogcmap.ashx?</url>
>>> >> >> >> <layer name="DOQ"/>
>>> >> >> >> <map-source name="usgs_drg" type="wms" tiled="false"
>>> >> >> >> <layer name="DRG"/>
>>> >> >> >> <map-source name="reference" type="wms" tiled="false"
>>> >> >> >> reference="true">
>>> >> >> >> <layer name="fsa2008" reference="true" /> </map-source> -->
>>> >> >> >> <service name="print" title="Print Map"> <step
>>> >> >> >> type="input"> <url>php/print.php</url> <input
>>> >> >> >> type="print_info" name="layers"/> <input type="extent"
>>> >> >> >> name="extent"/> <input type="sketches" name="sketches"/>
>>> >> >> >> <input type="user" name="title" title="Map
>>> >> >> >> Title">Map</input> <input type="hidden" name="date"
>>> >> >> >> title="Map Date">true</input>
>>> >> >> >> <input type="select" name="template" title="Output
>>> >> >> Template:
>>> >> >> >> <option value="letter_landscape">Letter -
>>> >> >> >> Landscape</option> <option value="letter_portrait">Letter -
>>> >> >> >> Portrait</option> <option value="poster_landscape">11" x
>>> >> >> >> 17" - Landscape</option> <option
>>> >> >> >> value="poster_portrait">11" x 17" - Portrait</option>
>>> >> >> >> </input>
>>> >> >> >> <input type="select" name="quality" title="Image
>>> >> Quality:
>>> >> >> >> <option value="2">Higher</option> <option
>>> >> >> >> value="3">Highest</option> <option
>>> >> >> >> value="1">Standard</option> </input>
>>> >> >> >> <input type="select" name="scale" title="Preserve
>>> >> Scale:
>>> >> >> >> <option value="preserve">Yes</option> <option
>>> >> >> >> value="no">No</option> </input> </step> </service>
>>> >> >> >> <service name="identify" title="Identify" display="false">
>>> >> >> >> <url>php/identify.php</url> <step type="spatial"
>>> >> >> >> name="shape" line="false"
>>> >> >> polygon="false"
>>> >> >> >> jump-start="true" default="point"> <input
>>> >> >> >> type="visiblelayers" name="layers"/> </step> </service>
>>> >> >> >> <service name="birdseye" display="false" target="_blank">
>>> >> >> >> <url>php/birdseye.php</url> <step type="spatial" name="xy"
>>> >> >> >> line="false"
>>> >> polygon="false"
>>> >> >> >> jump-start="true" default="point" format="delim"
>>> >> >> reproject="EPSG:4326">
>>> >> >> >> </step>
>>> >> >> >> </service>
>>> >> >> >> <service name="streetview" display="false" target="_blank">
>>> >> >> >> <url>php/streetview.php</url> <step type="spatial"
>>> >> >> >> name="xy" line="false"
>>> >> polygon="false"
>>> >> >> >> </step>
>>> >> >> >> </service>
>>> >> >> >> <service name="feature_report" display="false">
>>> >> >> >> <url>php/feature_report.php</url> <input type="hidden"
>>> >> >> >> name="layers" value="lmic/fsa"/> <input type="hidden"
>>> >> >> >> name="src"/> <input type="hidden" name="PIN"/> </service>
>>> >> >> >> <service name="select" title="Select">
>>> >> >> >> <url>php/select.php</url>
>>> >> >> >> <!-- Send a selection shape + the visible layers list
>>> to
>>> >> the
>>> >> >> >> service
>>> >> >> >> <step type="spatial" showTools="true" name="shape"
>>> >> >> line="true"
>>> >> >> >> polygon="true" point="true" default="polygon"
>>> edit-polygon="false"
>>> >> >> >> pan="false" jump-start="true">
>>> >> >> >> <header><![CDATA[Create a selection area by
>>> clicking
>>> >> on
>>> >> >> the
>>> >> >> >> map.]]></header>
>>> >> >> >> <input type="visiblelayers" name="layers"/>
>>> >> >> >> Option values should be the mapbook path to the
>>> >> >> layer.
>>> >> >> >> This only supports 'mapserver'-type layers.
>>> >> >> >> <input type="select" name="select_layer"
>>> >> title="Select:">
>>> >> >> >> <option
>>> value="parcels/parcels">Parcels</option>
>>> >> >> >> </input>
>>> >> >> >> <input type="user" name="shape_buffer"
>>> title="Buffer
>>> >> >> >> Selection
>>> >> >> >> Shape (ft)">0</input>
>>> >> >> >> <input type="select" name="query_layer"
>>> title="Using
>>> >> >> >> Features
>>> >> >> >> In">
>>> >> >> >> <option
>>> >> >> >> </input>
>>> title="Buffer
>>> >> >> >> Selection
>>> >> >> >> <footnote><![CDATA[
>>> >> >> >> ]]></footnote>
>>> >> >> >> </step>
>>> >> >> >> </service>
>>> >> >> >> <!-- this is called after a standard select in order to
>>> buffer
>>> >> >> the
>>> >> >> >> previous selection -->
>>> >> >> >> <service name="buffered_select_followup" title="Buffered
>>> >> Select">
>>> >> >> >> <step type="input">
>>> >> >> >> <input type="hidden" name="shape"/> <input type="hidden"
>>> >> >> >> name="select_layer"/> <input type="hidden"
>>> >> >> >> name="query_layer"/> <input type="hidden"
>>> >> >> >> name="shape_buffer"/> <input type="user"
>>> >> >> >> name="selection_buffer"
>>> >> title="Buffer
>>> >> >> >> Features By: "/>
>>> >> >> >> </step>
>>> >> >> >> </service>
>>> >> >> >> <service name="buffered_select" title="Buffered Select">
>>> to
>>> >> the
>>> >> >> >> service
>>> >> >> line="true"
>>> >> >> >> pan="false">
>>> clicking
>>> >> on
>>> >> >> the
>>> >> >> >> map.]]></header>
>>> >> >> layer.
>>> title="Select
>>> >> >> >> features
>>> >> >> >> from:">
>>> >> >> >> <option
>>> >> >> >> </input>
>>> >> >> >> <input type="user" name="selection_buffer"
>>> >> title="Buffer
>>> >> >> >> Selected Features (ft)">0</input>
>>> >> >> >> <!-- <input type="user" name="shape_buffer"
>>> >> title="Buffer
>>> >> >> >> Selection Shape (ft)">0</input>
>>> title="Using
>>> >> >> >> Features
>>> >> >> >> In">
>>> >> >> >> <option
>>> >> >> >> </input>
>>> >> >> >> <footnote><![CDATA[
>>> >> >> >> ]]></footnote>
>>> >> >> >> </step>
>>> >> >> >> </service>
>>> >> >> >> <service name="popups" display="false">
>>> >> >> >> <url>php/popups.php</url> <step type="spatial" name="shape"
>>> >> >> >> line="false"
>>> >> >> polygon="false"
>>> >> >> >> jump-start="true" default="point"> <header><![CDATA[ Click
>>> >> >> >> on the map to show a popup about the
>>> features.
>>> >> >> >> ]]></header>
>>> >> >> >> <input type="hidden" name="layer"/> </step> </service>
>>> >> >> >> <service name="geocode_address" title="Geocode Address">
>>> >> >> >> <url>php/geocode.php</url> <step type="input"> <input
>>> >> >> >> type="user" name="address" title="Enter
>>> >> Address:
>>> >> >> >> <input type="hidden" name="googlekey"
>>> value="ABQIAAAA4Q-VLyIpwp3L8M9DIzKb2BT2yXp_ZAY8_ufC3CFXhHIE1NvwkxRe8
>>> Hd6FR51Hvb-Fvd-wGjiDZDC4w"/>
>>> >> >> >> </step>
>>> >> >> >> </service>
>>> >> >> >> <service name="search_parcels"> <url>php/query.php</url>
>>> >> >> >> <step type="input"> <input type="hidden" name="highlight"
>>> value="true"/>
>>> >> >> >> <input type="hidden" name="mode" value="search"/>
>>> >> >> >> <input type="hidden" name="layer0"
>>> >> >> value="parcels/parcels"/>
>>> >> >> >> <input type="hidden" name="template0"
>>> >> value="itemquery"/>
>>> >> >> >> <input type="select" name="fieldname0"
>>> title="Search
>>> >> >> By:">
>>> >> >> >> <option value="OWNER_NAME">Owner</option> <option
>>> >> >> >> value="PIN">Parcel ID</option> </input> <input
>>> >> >> >> type="select" name="comparitor0"
>>> title="That:
>>> >> >> >> <option value="like-icase">Contains</option>
>>> >> >> >> <option value="right-like-icase">Begins
>>> >> With</option>
>>> >> >> >> <option value="eq-str">Matches Exactly</option> </input>
>>> >> >> >> <input type="user" name="value0" title=""/>
>>> >> >> >> <input type="hidden" name="fieldname1"
>>> >> >> value="FIN_SQ_FT"/>
>>> >> >> >> <input type="select" name="operator1"> <option
>>> >> >> >> value="or">OR</option> <option value="and">AND</option>
>>> >> >> >> </input> <input type="select" name="comparitor1"
>>> title="Having
>>> >> >> Fin.
>>> >> >> >> Sq.
>>> >> >> >> Ft. ">
>>> >> >> >> <option value="gt">Greater Than</option> <option
>>> >> >> >> value="eq">Equal To</option> <option value="lt">Less
>>> >> >> >> Than</option> </input> <input type="user" name="value1"
>>> >> >> >> title=""/> </step> </service>
>>> >> >> >> The catalog defines how the layers will be displayed in
>>> >> the
>>> >> >> >> catalog
>>> >> >> >> tab.
>>> >> >> >> <layer-controls>
>>> >> >> >> <layer-control name="popups" service-name="popups"
>>> >> >> >> layer-input="layer" on="false" tip="Show Popups for
>>> >> >> >> %LAYER%"/> </layer-controls> <catalog>
>>> >> >> >> <!-- <layer title="overallmap" src="parcels/parcels"
>>> >> >> status="on"
>>> >> >> >> popups="true" minscale="0" maxscale="150000"
>>> >> >> >> metadata="true" > <metadata>http://www.aqua3.com</metadata>
>>> >> >> >> </layer>
>>> >> >> >> <layer title="City and County Boundaries"
>>> >> src="borders/all"
>>> >> >> >> status="on"/>
>>> >> >> >> <layer title="Weather Radar" src="iastate/nexrad-n0r"
>>> >> >> >> status="off"
>>> >> >> >> legend="false"/>
>>> >> >> >> <group title="Backgrounds" expand="true"
>>> multiple="false">
>>> >> >> >> <layer title="Metro Base Map" src="metbase/Met
>>> Council
>>> >> >> Base
>>> >> >> >> Map
>>> >> >> >> Layers" status="on" legend="false" /> <layer title="2008
>>> >> >> >> Aerial Photographs"
>>> >> src="lmic/fsa2008"
>>> >> >> >> status="off" legend="false" /> <layer title="1997 Aerial
>>> >> >> >> Photographs"
>>> >> src="lmic/bw1997"
>>> >> >> >> status="off" legend="false" /> <layer title="USGS DOQs"
>>> >> >> >> src="usgs_doq/DOQ"
>>> >> status="off"
>>> >> >> >> fade="true" unfade="true" legend="false" /> <layer
>>> >> >> >> title="USGS Topo Quads" src="usgs_drg/DRG"
>>> >> >> >> status="off"
>>> >> >> >> title="None" src=" " status="off"
>>> >> legend="false"
>>> >> >> >> fade="false" unfade="false" />
>>> >> >> >> </group> -->
>>> >> >> >> </catalog>
>>> >> >> >> The toolbar defines which services are referneces in
>>> the
>>> >> >> toolbar
>>> >> >> >> <toolbar>
>>> >> >> >> <tool name="previous" title="Previous Extent"
>>> >> type="internal"
>>> >> >> >> action="previous" selectable="false"/> <tool name="next"
>>> >> >> >> title="Next Extent" type="internal"
>>> >> >> >> action="next"
>>> >> >> >> <tool name="fullextent" title="Zoom to Full Extent"
>>> >> >> >> type="internal"
>>> >> >> >> action="fullextent" selectable="false"/> <tool name="pan"
>>> >> >> >> title="Pan" type="internal"
>>> >> action="pan"/>
>>> >> >> >> <tool name="zoomin" title="Zoom In" type="internal"
>>> >> >> >> action="zoomin"
>>> >> >> >> selected="true"/>
>>> >> >> >> <tool name="zoomout" title="Zoom Out" type="internal"
>>> >> >> >> action="zoomout"/>
>>> >> >> >> <!-- <tool name="identify" title="Identify"
>>> >> type="service"
>>> >> >> >> service="identify" cursor="url('cursors/identify2.cur') 9
>>> >> >> >> 9,url('cursors/identify2.cur'),auto" /> -->
>>> >> >> >> <!-- <tool name="select" title="Select" type="service"
>>> >> >> >> service="select"/> -->
>>> >> >> >> <!-- <tool name="buffered_select" title="Buffered
>>> >> Select"
>>> >> >> >> type="service" service="buffered_select"/> -->
>>> >> >> >> <!-- <tool name="clear" title="Clear Selection"
>>> >> >> >> type="javascript"
>>> >> >> >> selectable="false">
>>> >> >> >> GeoMOOSE.changeLayerVisibility('highlight/all',
>>> >> false);
>>> >> >> >> </tool> -->
>>> >> >> >> <tool name="measure" title="Measure" type="internal"
>>> >> >> >> action="measure"/>
>>> >> >> >> <tool name="measurearea" title="Measure Area"
>>> >> type="internal"
>>> >> >> >> action="measurearea"/>
>>> >> >> >> <!-- <tool name="search_parcels" title="Search Parcels"
>>> >> >> >> type="service" service="search_parcels"
>>> >> >> >> <!-- <tool name="print" title="Print" type="service"
>>> >> >> >> service="print"
>>> >> >> >> selectable="false"/> -->
>>> >> >> >> <!-- <tool name="birdseye" title="Bird's Eye View"
>>> >> >> >> type="service"
>>> >> >> >> selectable="true" service="birdseye"/> -->
>>> >> >> >> <!-- <tool name="streetview" title="Google Street View"
>>> >> >> >> type="service" service="streetview" selectable="true"/> -->
>>> >> >> >> <!-- <tool name="geocode" title="Geocode Address"
>>> >> >> type="service"
>>> >> >> >> service="geocode_address" selectable="true"/> -->
>>> >> >> >> <!-- <drawer>
>>> >> >> >> <tool name="markup_tools" title="Sketch Tools"
>>> >> >> >> type="internal"
>>> >> >> >> action="none" selectable="false"/> <tool
>>> >> >> >> name="draw_polygon" title="Draw Polygon"
>>> >> >> >> type="internal"
>>> >> >> >> action="draw_polygon"/>
>>> >> >> >> <tool name="draw_line" title="Draw Line"
>>> >> type="internal"
>>> >> >> >> action="draw_line"/>
>>> >> >> >> <tool name="draw_point" title="Draw Point"
>>> >> >> type="internal"
>>> >> >> >> action="draw_point"/>
>>> >> >> >> <tool name="draw_remove" title="Remove Drawing"
>>> >> >> >> type="internal"
>>> >> >> >> action="draw_remove"/>
>>> >> >> >> <tool name="draw_edit" title="Edit Drawing"
>>> >> >> type="internal"
>>> >> >> >> action="draw_edit_shapes"/> <tool
>>> >> >> >> name="draw_edit_attributes" title="Edit
>>> >> Attributes"
>>> >> >> >> type="internal" action="draw_edit_attributes"/> <tool
>>> >> >> >> name="clear_drawings" title="Clear Drawings"
>>> >> >> >> type="internal" action="clear_drawings"
>>> >> >> >> selectable="false"/> </drawer> --> </toolbar> </mapbook>
>>> >> >> >> ============= END OF MAPBOOK.XML =============
>>> >> >> >> I have tried getting some error reporting out of firebug
>>> >> >> >> with
>>> >> little
>>> >> >> >> success, if anyone can help me spot what I have done wrong
>>> >> >> >> it
>>> >> would
>>> >> >> be
>>> >> >> >> much
>>> >> >> >> appreciated and I would be happy to supply the real url's
>>> >> >> >> to
>>> the
>>> >> >> server
>>> >> >> >> off-list.
>>> >> >> >> Cheers
>>> >> >> >> Carl
>>> >> >> >> Protect Your Site and Customers from Malware Attacks Learn
>>> >> >> >> about various malware tactics and how to avoid them.
>>> >> Understand
>>> >> >> >> malware threats, the impact they can have on your business,
>>> and
>>> >> how
>>> >> >> you
>>> >> >> >> can protect your company and customers by using code signing.
>>> http://p.sf.net/sfu/oracle-sfdevnl__________________________________
>>> _____________
>>> >> >> >> Geomoose-users mailing list
>>> >> >> >> Geomoose-users at lists.sourceforge.net
>>> >> >> >> https://lists.sourceforge.net/lists/listinfo/geomoose-users
>>> >> >> > Best Regards
>>> >> >> > Brent Fraser
>>> >> Understand
>>> >> >> > and
>>> how
>>> >> >> you
>>> >> >> > _______________________________________________
>>> >> >> Best Regards
>>> >> >> Brent Fraser
>>> Understand
>>> >> > malware threats, the impact they can have on your business, and
>>> how
>>> >> you
>>> _____________
>>> >> Best Regards
>>> >> Brent Fraser
>>> > Protect Your Site and Customers from Malware Attacks Learn about
>>> > various malware tactics and how to avoid them. Understand malware
>>> > threats, the impact they can have on your business, and how
>>> you
>>> _____________
>>> Best Regards
>>> Brent Fraser
> Best Regards
> Brent Fraser
Best Regards
Brent Fraser
Protect Your Site and Customers from Malware Attacks Learn about various malware tactics and how to avoid them. Understand malware threats, the impact they can have on your business, and how you can protect your company and customers by using code signing.
More information about the Geomoose-users mailing list
