[Geomoose-users] User id
Brent Fraser bfraser at geoanalytic.com
Tue Jan 18 10:40:48 EST 2011
Dean,
   I'd be interested in that.  I expect we'll have a need to do some
collaboration between two or three users on our mapping site, so that
might be a start.  I had also considered having a tab for a "chat"
window (which implies a a chat server, etc)...
Best Regards,
Brent Fraser
On 1/18/2011 8:31 AM, DEAN ANDERSON wrote:
> We have a "bookmark" tool which allows users to save basic settings
> such as the last selected set, mapextent and which layers are turned
> off or on.  The bookmark is printed in the results tab and can be used
> as a book mark, e-mailed, etc. We use this to support different groups
> or individuals within the county so that their default views are saved
> and accessible.   This might be modified to fit what you may need.
> Dean Anderson
> Polk County, Oregon
> >>> Brent Fraser <bfraser at geoanalytic.com> 1/18/2011 7:25 AM >>>
> Carl,
> On way is to save it as a session variable in your server-side
> scripting.  However if your existing site (where they log in) and your
> new mapping site are on different servers, you'll need to do something
> else.
> Best Regards,
> Brent Fraser
> On 1/18/2011 7:35 AM, Carl Burn wrote:
>> Hello all,
>> I have my app working in geomoose and am getting the layers working
>> thanks to a lot of help from the list. I have another question for
>> the list, again it may be a dumb one but here goes.
>> My users will access the app from a site that already exists and will
>> do so once logged in, I can pass across a user id on the url (as part
>> of the query string) or as a form variable. The users will then make
>> whatever changes to the map they need (turning layers on and off) and
>> save those changes, I plan to do this by saving into a database and
>> along with the map layer information I would need to save the user id
>> from the url so I can pair up users with their saved map details
>> later on when they are back in the main site.
>> Is there a recognised way to do this in geomoose or does anyone have
>> any suggestions.
>> Best
>> Carl
>> Protect Your Site and Customers from Malware Attacks
>> Learn about various malware tactics and how to avoid them. Understand
>> malware threats, the impact they can have on your business, and how you
>> can protect your company and customers by using code signing.
>> http://p.sf.net/sfu/oracle-sfdevnl
>> Geomoose-users mailing list
>> Geomoose-users at lists.sourceforge.net
>> https://lists.sourceforge.net/lists/listinfo/geomoose-users
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20110118/b467124c/attachment.html
More information about the Geomoose-users mailing list
