[Geomoose-users] User id
Bob Basques Bob.Basques at ci.stpaul.mn.us
Tue Jan 18 10:57:51 EST 2011
All,
I've been in conversations exploring the idea of a chat window inside of GeoMoose as well.  Things like being able to pass view characteristics, and such to another user, things like that.  Our preferred protocol would be to use JABBER.  We've used it quite a bit in the past for different (but similar) things.  The ability to log a session in Jabber as well as set up secure groups is another plus, and allows for some interesting ways to post information about a particular GeoMoose view, etc, to a wider audience, without complicating the geomoose code too extensively.
No way around there being a need for some sort of server component for this though.  How would others envision something like this being implemented?   Seems like a plausible user extension.
I have access to a Jabber service for trying some things out if anyone else is game?
bobb
>>> Brent Fraser <bfraser at geoanalytic.com> wrote:
Dean,
  I'd be interested in that.  I expect we'll have a need to do some collaboration between two or three users on our mapping site, so that might be a start.  I had also considered having a tab for a "chat" window (which implies a a chat server, etc)...
Best Regards,
Brent Fraser
On 1/18/2011 8:31 AM, DEAN ANDERSON wrote:
We have a "bookmark" tool which allows users to save basic settings such as the last selected set, mapextent and which layers are turned off or on.  The bookmark is printed in the results tab and can be used as a book mark, e-mailed, etc. We use this to support different groups or individuals within the county so that their default views are saved and accessible.   This might be modified to fit what you may need.
Dean Anderson
Polk County, Oregon
>>> Brent Fraser <bfraser at geoanalytic.com> ( mailto:bfraser at geoanalytic.com ) 1/18/2011 7:25 AM >>>
Carl,
On way is to save it as a session variable in your server-side scripting.  However if your existing site (where they log in) and your new mapping site are on different servers, you'll need to do something else.
Best Regards,
Brent Fraser
On 1/18/2011 7:35 AM, Carl Burn wrote:
Hello all,
I have my app working in geomoose and am getting the layers working thanks to a lot of help from the list. I have another question for the list, again it may be a dumb one but here goes.
My users will access the app from a site that already exists and will do so once logged in, I can pass across a user id on the url (as part of the query string) or as a form variable. The users will then make whatever changes to the map they need (turning layers on and off) and save those changes, I plan to do this by saving into a database and along with the map layer information I would need to save the user id from the url so I can pair up users with their saved map details later on when they are back in the main site.
Is there a recognised way to do this in geomoose or does anyone have any suggestions.
Best
Carl
Protect Your Site and Customers from Malware Attacks
Learn about various malware tactics and how to avoid them. Understand
malware threats, the impact they can have on your business, and how you
can protect your company and customers by using code signing.
http://p.sf.net/sfu/oracle-sfdevnl
Geomoose-users mailing list
Geomoose-users at lists.sourceforge.net
https://lists.sourceforge.net/lists/listinfo/geomoose-users
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20110118/d9b03ed5/attachment.html
More information about the Geomoose-users mailing list
