[Geomoose-users] User id
Carl Burn burnsy at northcountrywoods.co.uk
Tue Jan 18 11:07:29 EST 2011
Hi Dean,
that sounds like it might pretty much do the job with very little
modification, is this something I can download and install.
Once again thanks to all for the responses.
Carl
On Tue, Jan 18, 2011 at 3:31 PM, DEAN ANDERSON
<ANDERSON.DEAN at co.polk.or.us>wrote:
>  We have a "bookmark" tool which allows users to save basic settings such
> as the last selected set, mapextent and which layers are turned off or on.
> The bookmark is printed in the results tab and can be used as a book mark,
> e-mailed, etc. We use this to support different groups or individuals within
> the county so that their default views are saved and accessible.
> This might be modified to fit what you may need.
> Dean Anderson
> Polk County, Oregon
> >>> Brent Fraser <bfraser at geoanalytic.com> 1/18/2011 7:25 AM >>>
> Carl,
> On way is to save it as a session variable in your server-side scripting.
> However if your existing site (where they log in) and your new mapping site
> are on different servers, you'll need to do something else.
> Best Regards,
> Brent Fraser
> On 1/18/2011 7:35 AM, Carl Burn wrote:
> Hello all,
> I have my app working in geomoose and am getting the layers working thanks
> to a lot of help from the list. I have another question for the list, again
> it may be a dumb one but here goes.
> My users will access the app from a site that already exists and will do so
> once logged in, I can pass across a user id on the url (as part of the query
> string) or as a form variable. The users will then make whatever changes to
> the map they need (turning layers on and off) and save those changes, I plan
> to do this by saving into a database and along with the map layer
> information I would need to save the user id from the url so I can pair up
> users with their saved map details later on when they are back in the main
> site.
> Is there a recognised way to do this in geomoose or does anyone have any
> suggestions.
> Best
> Carl
> Protect Your Site and Customers from Malware Attacks
> Learn about various malware tactics and how to avoid them. Understand
> malware threats, the impact they can have on your business, and how you
> can protect your company and customers by using code signing.http://p.sf.net/sfu/oracle-sfdevnl
> Geomoose-users mailing listGeomoose-users at lists.sourceforge.nethttps://lists.sourceforge.net/lists/listinfo/geomoose-users
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20110118/3b32227d/attachment.html
More information about the Geomoose-users mailing list
