[Geomoose-users] Mapserver templating and geomoose
Brent Fraser bfraser at geoanalytic.com
Sat Jun 4 15:42:28 EDT 2011
I see that there's a function called processTemplate in identify.php
which would over-ride the Mapscript one.  Or it could be that
[scaledenom] is not relevant for query processing (it's a map display
thing).
Best Regards,
Brent Fraser
On 6/4/2011 11:22 AM, aborruso wrote:
> Hi Brent,
> there is something that I did not understand.
> Brent Fraser wrote:
>> "Only tags that have an equivalent element in the map object are replaced"
> One tag that should have an equivalent element in the map object is
> [scaledenom]. You car read it in the documentation.
> I have added it to header.html file and I do not have the scale denom value
> but once again the string "[scaledenom]".
> Why is it not replaced?
> Thank you,
> Andrea
> View this message in context: http://geomoose-users.964460.n3.nabble.com/Mapserver-templating-and-geomoose-tp3023495p3023742.html
> Sent from the Geomoose-users mailing list archive at Nabble.com.
> Simplify data backup and recovery for your virtual environment with vRanger.
> Installation's a snap, and flexible recovery options mean your data is safe,
> secure and there when you need it. Discover what all the cheering's about.
> Get your free trial download today.
> http://p.sf.net/sfu/quest-dev2dev2
> Geomoose-users at lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geomoose-users
More information about the Geomoose-users mailing list
