[Geomoose-users] WMS raster layer won't print
Dan Little danlittle at yahoo.com
Fri Jun 24 08:24:40 EDT 2011
Hi Jim, did you get an answer to this question?
Do you have control over the WMS service?  There is a chance that the print-request is asking for an image larger than the server will allow to be rendered.
>________________________________
>From: Jim <jauld at city.kawarthalakes.on.ca>
>To: geomoose-users at lists.sourceforge.net
>Sent: Wednesday, June 15, 2011 9:17 AM
>Subject: [Geomoose-users] WMS raster layer won't print
>I have a WMS layer coming from Geoserver as a base layer on my map - it is in
>the same projection as all the other layers.  When I go to print a map, the
>WMS layer (it's an aerial photo raster) doesn't show up, but all other
>layers do.  After checking a number of the other maps in the Geomoose
>gallery, I've found that about 75% of them have the same problem - base
>raster layers fail to show up when printing the map, so it's obviously a
>fairly widespread problem. Has anyone found out what causes this failure and
>how to fix it?
>View this message in context: http://geomoose-users.964460.n3.nabble.com/WMS-raster-layer-won-t-print-tp3067473p3067473.html
>Sent from the Geomoose-users mailing list archive at Nabble.com.
>EditLive Enterprise is the world's most technically advanced content
>authoring tool. Experience the power of Track Changes, Inline Image
>Editing and ensure content is compliant with Accessibility Checking.
>http://p.sf.net/sfu/ephox-dev2dev
>_______________________________________________
>Geomoose-users at lists.sourceforge.net
>https://lists.sourceforge.net/lists/listinfo/geomoose-users
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20110624/44b95882/attachment.html
More information about the Geomoose-users mailing list
