[Geomoose-users] How to create an additional website
Dan Little danlittle at yahoo.com
Tue Jun 28 13:54:59 EDT 2011
Hi Ed,
It sorta "depends."  Minimally, each GeoMOOSE instance needs a copy of htdocs and conf.  The data can be shared across applications, or isolated, you just need to configure the Mapbook to point to the right files.
You will need to create the appropriate apache alias for different folders.
>________________________________
>From: "Ed Boesenberg, III" <eboesenberg at niraengineers.com>
>To: Geomoose Support <geomoose-users at lists.sourceforge.net>
>Sent: Tuesday, June 28, 2011 12:04 PM
>Subject: [Geomoose-users] How to create an additional website
>I would like setup a few Geomoose websites for different
clients and I would like each to have their own folder under "Apps".
What files and folders need to be copied from the original Geomoose apps
folder?  Do I need to modify any Apache files for this to work?
>Thanks,
>Ed Boesenberg, III
>All of the data generated in your IT infrastructure is seriously valuable.
>Why? It contains a definitive record of application performance, security
>threats, fraudulent activity, and more. Splunk takes this data and makes
>sense of it. IT sense. And common sense.
>http://p.sf.net/sfu/splunk-d2d-c2
>_______________________________________________
>Geomoose-users mailing list
>Geomoose-users at lists.sourceforge.net
>https://lists.sourceforge.net/lists/listinfo/geomoose-users
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20110628/23b23faf/attachment.html
More information about the Geomoose-users mailing list
