[Geomoose-users] Migrating geomoose v1.6 Microsoft to Linux
Dan Little danlittle at yahoo.com
Thu Jun 30 14:52:36 EDT 2011
Your PHP does not have Curl or Dbase built into it.  You might be hardpressed to make it work but what you'll need to do is grab a version of PHP 5.2 and build it yourself with Curl, GD, and Dbase built into it.  GeoMOOSE 2.4 removed the dependency on Dbase by moving to SQLite.
>________________________________
>From: geo3d <geomatrix3d at gmail.com>
>To: geomoose-users at lists.sourceforge.net
>Sent: Thursday, June 30, 2011 12:44 PM
>Subject: Re: [Geomoose-users] Migrating geomoose v1.6 Microsoft to Linux
>Brent thanks again for the response; I went digging through my apache log and
>the error generated when trying to either 'select' or 'print':
>PHP Fatal error:  Call to undefined function dl() in
>/var/www/iMap/Test/php/geomoose_php_util.php on line 25, referer:
>http://maps.peachtree-city.org/iMap/Test/
>So a look at geomoose_php_util.php line 25:
>if(!extension_loaded('dbase')) {
>    dl('*php_dbase*.'.PHP_SHLIB_SUFFIX);
>Additionally, the error did read for line 17 vs 25 which referred to
>'php_curl': simply changing the geomoose_php_util.php to read 'curl' on line
>17 fixed that error.
>Some further reading I came across this:
>http://osgeo-org.1803224.n2.nabble.com/Fatal-error-Call-to-undefined-function-dl-in-C-ms4w-Apache-htdocs-phpmapscript-php-on-line-5-td4092107.html
>which refers to this removal: Since PHP version 5.3.0 you can no longer use
>PHP's dl() function (it
>has been deprecated and removed as noted in
>http://ca2.php.net/manual/en/function.dl.php).
>Perhaps I'm reading too much into this but if loading the dlls and referring
>to them directly via the php.ini file; what dlls are we referring to
>regarding the 'php_dbase'
>I did try simply turning enable dl=On in the php.ini with no luck.
>I am using Webmin and there is a php module per virtualhost configuration;
>anyone with some Webmin knowledge in configuring that referred php module?
>View this message in context: http://geomoose-users.964460.n3.nabble.com/Migrating-geomoose-v1-6-Microsoft-to-Linux-tp3125537p3126853.html
>Sent from the Geomoose-users mailing list archive at Nabble.com.
>All of the data generated in your IT infrastructure is seriously valuable.
>Why? It contains a definitive record of application performance, security
>threats, fraudulent activity, and more. Splunk takes this data and makes
>sense of it. IT sense. And common sense.
>http://p.sf.net/sfu/splunk-d2d-c2
>_______________________________________________
>Geomoose-users at lists.sourceforge.net
>https://lists.sourceforge.net/lists/listinfo/geomoose-users
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20110630/a29cbd7f/attachment.html
More information about the Geomoose-users mailing list
