[Geomoose-users] Configure Identify and query
Eli Adam eadam at co.lincoln.or.us
Sun Mar 27 21:53:01 EDT 2011
I think that the file Dean sent last week is a good start.  It is the rtf attached to this message, http://sourceforge.net/mailarchive/message.php?msg_id=27253373
I think it would be better on the wiki than an attachment on the email list and it could use some further explanations and some typo fixing.  To get that started, I have put that on the wiki here:
http://geomoose.org/wiki/index.php/Setup_guide
Also on the wiki about identify and query:
http://geomoose.org/wiki/index.php/Identify_on_specified_layers
http://geomoose.org/wiki/index.php/Query_Service
Feel free to make contributions or improvements to the wiki.
Bests, Eli
>>> Dan Little <danlittle at yahoo.com> 03/26/11 4:33 PM >>>
That is a fair assessment of the condition of the documentation.
Oregon guys? BrentF? BrianF? Anyone want to write a doc or docs?
----- Original Message ----
> From: aborruso <aborruso at gmail.com>
> To: geomoose-users at lists.sourceforge.net
> Sent: Sat, March 26, 2011 5:17:50 PM
> Subject: Re: [Geomoose-users] Configure Identify and query
> Hi Dan,
> Dan Little wrote:
> > Can you give a little more  specifics?  There are a few layers configured
> > in the
> > demo  and I do see (now) that the docs are a bit abysmal.
> I think that it  should be a doc that explains the necessary steps  to make
> "queryable" a  layer.
> In example, "if you want to use identify tool, you must add to  layer
> metadata a row with 'identify_record'     'identify_layername.html'. To use
> popup tool, you instead must create  ..."
> To reach this goal at the moment it's necessary to do a sort of  reverse
> engineering.
> This is for me, I do not know if Bob agrees with  me.
> Once again, thank you,
> a
> View this message in  context:
>http://geomoose-users.964460.n3.nabble.com/Geomoose-users-Configure-Identify-and-query-tp2725261p2737139.html
> Sent  from the Geomoose-users mailing list archive at  Nabble.com.
> Enable  your software for Intel(R) Active Management Technology to meet the
> growing  manageability and security demands of your customers. Businesses
> are taking  advantage of Intel(R) vPro (TM) technology - will your software
> be a part of  the solution? Download the Intel(R) Manageability Checker
> today! http://p.sf.net/sfu/intel-dev2devmar
> Geomoose-users at lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geomoose-users
More information about the Geomoose-users mailing list
