[Geomoose-users] Drop-down, file browse at Add point service
Matej Mailing mailing at tam.si
Wed Nov 9 04:14:54 EST 2011
Brent, thanks!
I should have read the documentation more carefully ... :-)
With best regards,
Matej
2011/11/8 Brent Fraser <bfraser at geoanalytic.com>
>  Matej,
>   For the drop down combo box, have a look at the Mapbook Reference Guide
> doc (http://www.geomoose.org/docs/mapbook.html), specifically the
> <service> section on using type=select and type=ajax_select.
>   The Open File dialog is tougher.  There is no direct support in a
> GeoMoose <service> for this input type, but you should be able to add the
> user interface part (a link? a button?) by using GeoMoose User Extensions (
> http://www.geomoose.org/docs/user_extensions.html).  The sending of the
> file contents to the server (and doing something with it) could be a bit of
> work too.  I found some general info at
> http://code.google.com/p/upload-at-click/
> Best Regards,
> Brent Fraser
> On 11/8/2011 2:43 AM, Matej Mailing wrote:
> Hi all,
> what would be the best way to get a drop down (to limit the possible
> entries) and file browse (to save file to a BLOB) when adding points?
> Currently we have only direct text entries and the app can be significantly
> faster with using those two options. On the other side the parameters both
> have a value which (I suppose) can be handled similarily as with the text
> entry box.
> Thanks for all the ideas in advance :-)
> Matej
> RSA(R) Conference 2012
> Save $700 by Nov 18
> Register nowhttp://p.sf.net/sfu/rsa-sfdev2dev1
> Geomoose-users mailing listGeomoose-users at lists.sourceforge.nethttps://lists.sourceforge.net/lists/listinfo/geomoose-users
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20111109/a827ca2b/attachment-0001.html
More information about the Geomoose-users mailing list
