[Geomoose-users] Problem adding a link to the identify results
Brent Fraser bfraser at geoanalytic.com
Wed Nov 9 16:57:46 EST 2011
I keep a copy of UltraEdit around for its awesome Column Mode
Best Regards,
Brent Fraser
On 11/9/2011 2:47 PM, Bob Basques wrote:
> Ultraedit is another good editor, most of the same features, also lets
> you keep editing projects organized and allows for batch editing and
> replace across many files.
> bobb
> >>> Brent Fraser <bfraser at geoanalytic.com> wrote:
> Some document editors (e.g. Word) "help" you by changing text.  I like
> using Notepad++ to keep it simple.  It colorizes the text so I can
> tell if things are commented out or quoted, and it highlights
> open/closing tags in html and xml.
> Best Regards,
> Brent Fraser
> On 11/9/2011 2:33 PM, Ed Boesenberg, III wrote:
>> Thanks, that worked.  I don't know how the back-double-quotes even
>> got there, I don't know how to type them in either.
>> *From:* Brent Fraser [mailto:bfraser at geoanalytic.com]
>> *Sent:* Wednesday, November 09, 2011 4:13 PM
>> *To:* Ed Boesenberg, III
>> *Cc:* 'Ed Boesenberg'; geomoose-users at lists.osgeo.org
>> *Subject:* Re: [Geomoose-users] Problem adding a link to the identify
>> results
>> Ed,
>>   IE is not very forgiving with HTML that deviates from the spec.  I
>> changed the back-double-quote (”) to a forward?-double-quote (") and
>> it rendered properly.
>> Best Regards,
>> Brent Fraser
>> On 11/9/2011 1:21 PM, Ed Boesenberg, III wrote:
>> I mean that no text is being rendered.  It is being rendered if I DO
>> NOT place my code, as shown in the previous email, into the identify
>> html.
>> It worked in GM 2.0 but not the current GM 2.4 version.
>> *From:*geomoose-users-bounces at lists.osgeo.org
>> <mailto:geomoose-users-bounces at lists.osgeo.org> [mailto:geomoose-users-bounces at lists.osgeo.org]
>> *On Behalf Of *Brent Fraser
>> *Sent:* Wednesday, November 09, 2011 1:05 PM
>> *To:* Ed Boesenberg
>> *Cc:* geomoose-users at lists.osgeo.org
>> <mailto:geomoose-users at lists.osgeo.org>
>> results
>> If you mean the PIN is not being substituted, it needs to be
>> lowercase for a database column name but uppercase for a shapefile
>> field (a Mapserver thing).  If you mean no text at all is being
>> rendered, likely mapserver can't find indentify.html ?
>> Best Regards,
>> Brent Fraser
>> On 11/9/2011 10:53 AM, Ed Boesenberg wrote:
>> Why do results not show up in the Information tab if the code below
>> is added to an identify html file or popup html file?
>> <tr>
>> <td> <a
>> href="http://www2.county.allegheny.pa.us/RealEstate/GeneralInfo.aspx?ParcelID=[PIN]"
>> <http://www2.county.allegheny.pa.us/RealEstate/GeneralInfo.aspx?ParcelID=%5bPIN%5d> target=”_blank”>See
>> Owner Info on Allegheny County Website</a></td>
>> </tr>
>> Thanks,
>> Ed Boesenberg
>> Geomoose-users mailing list
>> Geomoose-users at lists.osgeo.org <mailto:Geomoose-users at lists.osgeo.org>
>> http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20111109/a9679b84/attachment-0001.html
More information about the Geomoose-users mailing list
