[Geomoose-users] Identify- order of results
Eli Adam eadam at co.lincoln.or.us
Wed Nov 30 12:00:45 EST 2011
Bob,
Changing the order of the <map-source> in the mapbook.xml changes the
order for me.
HTH, Eli
On Wed, Nov 30, 2011 at 7:40 AM, Bob Bistrais <Bob.Bistrais at maine.gov> wrote:
> When the Identify tool is used, I want to control the order of layers when
> the results are presented in the right side window.  Basically, I want to
> present the coordinates, then layer “a”, then layer “b”.  In fact, when I
> look in FireBug, the Response and XML results show exactly what I want to
> see.  But the actual results in the window show layer “b” before “a”.  I’ve
> also dumped the results to a text file, again, it looks like what I want,
> but not what I get in the result window.  Why is this, and is there anything
> I can do to change it?
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users mailing list
