[Geomoose-users] Verify Mapbook Service
gayani gayani.edirisinghe at gmail.com
Fri Oct 7 01:42:49 EDT 2011
Thanks for your reply.  And I need to know how can I call to variable '$dis'
within the .map file that called from perticular service.
Thanks
Gayani Edirisinghe
On Thu, Oct 6, 2011 at 7:09 PM, Dan Little [via Geomoose-users] <
ml-node+s964460n3399698h57 at n3.nabble.com> wrote:
> This isn't really complete enough for us to diagnose everything that's
> going on.  Again, my previous email suggests using Firebug to ensure that
> the service is being called, it applies here too.
> The big problem I see is that you are passing URL style key-value pairs to
> startService, which is actually expecting a javascript-object.
> Your print statment should look like this:
> print "javascript:GeoMOOSE.startService('query_dis', {'dis' : '".$dis."')"
> Have you looked into using query.php for any of your queries?
> *From:* gayani <[hidden email]<http://user/SendEmail.jtp?type=node&node=3399698&i=0>
> *To:* [hidden email]<http://user/SendEmail.jtp?type=node&node=3399698&i=1>
> *Sent:* Wednesday, October 5, 2011 11:18 PM
> *Subject:* [Geomoose-users] Verify Mapbook Service
> Hi,
> I need to call to service in map book through php script.  How can I verify
> the service working properly.  The coding and information of the process is
> as follows.
> calling to service from php file
> print " javascript:GeoMOOSE.startService('query_dis','dis=".$dis."')  List
> of district projects ";
> Here call to the service query_dis with variable.
> serive in map book is
>                         <service name="quey_dis" selectable="false"
> default="false" locked="true" >
>                                         <url>/cgi-bin/mapserv.exe?</url>
>                                         <input type="hidden"
> value="Proceed"/>
>                                         <input type="hidden" name="map"
> value="/ms4w/apps/geomoose2/maps/demo/disquery/districtpro.map"/>
>                                         <input type="hidden" name="mode"
> value="NQUERY"/>
>                                         <input type="hidden" name="sector"
> value=""/>
>                         </service>
> Do you have any experience on this?
> http://geomoose-users.964460.n3.nabble.com/Verify-Mapbook-Service-tp3398734p3398734.html
> Sent from the Geomoose-users mailing list archive at Nabble.com.
> [hidden email] <http://user/SendEmail.jtp?type=node&node=3399698&i=2>
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
> [hidden email] <http://user/SendEmail.jtp?type=node&node=3399698&i=3>
>  If you reply to this email, your message will be added to the discussion
> below:
> http://geomoose-users.964460.n3.nabble.com/Verify-Mapbook-Service-tp3398734p3399698.html
>  To unsubscribe from Verify Mapbook Service, click here<http://geomoose-users.964460.n3.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=3398734&code=Z2F5YW5pLmVkaXJpc2luZ2hlQGdtYWlsLmNvbXwzMzk4NzM0fDIwMTE5NTA3OTk=>.
View this message in context: http://geomoose-users.964460.n3.nabble.com/Verify-Mapbook-Service-tp3398734p3401986.html
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20111006/89fe426f/attachment.html
More information about the Geomoose-users mailing list
