[Geomoose-users] Printing Problem - Empty Template
Dan Little danlittle at yahoo.com
Thu Oct 20 18:47:21 EDT 2011
Check the "server_name" parameter in the settings.ini file.
Your server may not recognize itself as "localhost".
>________________________________
>From: Jes Wohlfeil <wohlfeil at alputilities.com>
>To: geomoose-users at lists.osgeo.org
>Sent: Thursday, October 20, 2011 4:24 PM
>Subject: Re: [Geomoose-users] Printing Problem - Empty Template
>Everything is the same other than any paths that I found that needed to be
>changed.  It is putting pdf and jpg files in the temp directory, but the pdf
>only shows the template and the jpg is just a white image.  I will check
>into the permissions.
>Thanks
>Jes
>Jes Wohlfeil
>Alexandria Light & Power
>View this message in context: http://geomoose-users.964460.n3.nabble.com/Printing-Problem-Empty-Template-tp3438628p3439053.html
>Sent from the Geomoose-users mailing list archive at Nabble.com.
>_______________________________________________
>Geomoose-users at lists.osgeo.org
>http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20111020/5bbc9a97/attachment.html
More information about the Geomoose-users mailing list
