[Geomoose-users] Identify Not Working
Dan Little danlittle at yahoo.com
Fri Sep 2 10:59:48 EDT 2011
That error means it's having problems parsing your mapfile.  Check a few things:
1) Ensure path is set correctly in settings.ini.
2) That the name you're passing in is the same spelling (capitalization matters) in the mapbook and in the mapfile.
>________________________________
>From: "Ed Boesenberg, III" <eboesenberg at niraengineers.com>
>To: geomoose-users at lists.sourceforge.net
>Sent: Thursday, September 1, 2011 4:01 PM
>Subject: [Geomoose-users] Identify Not Working
>Good News, I convinced a client to move forward with having
me create an internal website using their GIS data (water and sewers).
>Bad News, I have not been able to get the indentify function
to work.  I receive an error message stating "Fatal error: Call to a member function queryByPoint() on a non-object in
D:\ms4w\apps\ftmagisapp_v1\htdocs\php\identify.php on line 125".  I
changed the projection of the map to EPSG 2272.  I changed the projection
in the mapfile, in mapbook.xml, in settings.ini and also added the projection
script to geomoose.html.
>Is there somewhere else I need to
specify the projection?
>Ed Boesenberg, III
>Special Offer -- Download ArcSight Logger for FREE!
>Finally, a world-class log management solution at an even better
>price-free! And you'll get a free "Love Thy Logs" t-shirt when you
>download Logger. Secure your free ArcSight Logger TODAY!
>http://p.sf.net/sfu/arcsisghtdev2dev
>_______________________________________________
>Geomoose-users mailing list
>Geomoose-users at lists.sourceforge.net
>https://lists.sourceforge.net/lists/listinfo/geomoose-users
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20110902/2774d83e/attachment.html
More information about the Geomoose-users mailing list
