[Geomoose-users] Yahoo Layer wrong projection
Dan Little danlittle at yahoo.com
Mon Apr 2 14:30:57 EDT 2012
According to that configuration, your application is using your native projection, but Yahoo uses Web Mercator.  So you have a few options:
1. Don't use the Yahoo satellite imagery.  This will require you to find a local data source in a format you can serve (think GeoTIFF, ERW, JPEG2000 with Geo attributes attached, Mr SID, lots of options here).
2. Convert your data sources to display in Web Mercator.  If your source data is in the local projection then you can either create projected data sources or you can have mapserver do the dirty work and have it project it out as a part of the WMS configuration.
>________________________________
> From: maddqc <qc_mad at hotmail.com>
>To: geomoose-users at lists.osgeo.org
>Sent: Thursday, March 29, 2012 3:09 PM
>Subject: [Geomoose-users] Yahoo Layer wrong projection
>Hi list,
>I have a problem that is giving me headache. My problem is that I'm trying
>to show a Yahoo satellite layer, but it seems that my projection is...kinda
>wrong because my map show right at the middle of the Mediterranean Sea, when
>it's supposed to show right over Quebec (Canada).
>I've set my projection to EPSG:32188
>Here is the place where I've set this:
>In my main .HTML
>In my Mapbook:
>EPSG:32187
>In Compiled.js:
>'projection' : "EPSG:32188",
>In my Settings.ini:
>[map]
>projection=EPSG:32188
>Seriously...what's wrong with that???
>Thanks to all of you!!! Your help is really appreciated.
>View this message in context: http://geomoose-users.964460.n3.nabble.com/Yahoo-Layer-wrong-projection-tp3868924p3868924.html
>Sent from the Geomoose-users mailing list archive at Nabble.com.
>_______________________________________________
>Geomoose-users at lists.osgeo.org
>http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20120402/1f9ea437/attachment.html
More information about the Geomoose-users mailing list
