[Geomoose-users] 2.6 - To Doc? To Purge? To Release?
Eli Adam eadam at co.lincoln.or.us
Thu Apr 12 13:49:42 EDT 2012
bobb,
      Hopefully the online validator would work well enough to avoid bad
stuff.  If you want to attach to a ticket I will gladly apply it.  If you
want, I can try to help you get sphinx running in your local environment so
that you can run locally.
      I'm not opposed to you committing it and breaking rendering things
and then me fixing it after you, so long as you were reasonably confident
that your changes weren't going to break things (which perhaps an online
validator would do) and/or you promptly check your commits online and
revert them if they cause problems.  However, such a thing should be rare
(perhaps use two online validators if using one in the past didn't work).
Also, other people may feel differently about commits breaking rendering
things.  I also can't speak for the infrastructure.  If your changes were
enough to impact the infrastructure, I can imagine that would be
unpopular.
     I'm sure that we can work something out.
Bests, Eli
On Thu, Apr 12, 2012 at 10:38 AM, Bob Basques
<Bob.Basques at ci.stpaul.mn.us>wrote:
>  All,
>  Ok, last time I tried this, I did the Sphinx stuff by hand and validated
> it online with a SPHINX validator and then posted.  Apparently this was
> bad, since I got thrown out of documentation class as a consequence.  See
> my remark about not being afraid of writing doc's but being told I did it
> wrong.
>  bobb
> >>> Eli Adam <eadam at co.lincoln.or.us> wrote:
> Ed and Bob (Bistrais in addition to bobb), Dan, and all,
> Thanks for volunteering with documentation writing.  The docs are
> generated using sphinx (http://sphinx.pocoo.org/) which just uses
> restructured text which is fairly simple txt files.  You can look at
> them here,
> http://trac.osgeo.org/geomoose/browser/geomoose2/trunk/sphinx-docs/source
> Also, anywhere on the website you can click the 'Show Source' link
> under 'This Page'.  Looking at and mimicking the existing files works
> fairly well for me.
> The general workflow for writing docs is to svn checkout/update, write
> the documentation locally, have sphinx  installed and locally build
> the documentation, check that it is all correct, create a patch and
> attach to a ticket (http://trac.osgeo.org/geomoose/report) or svn
> commit, the website will reflect your changes 15 minutes or so after
> it is committed.
> If you want to use that workflow, I'm available to help offline to get
> subversion and sphinx set up in your environment.  If you don't want
> to use that workflow, then you can open tickets and just put the
> documentation in the ticket and I will convert it to the correct
> format and get it on the website.
> > Does anyone have an objection to cleaning up the docs to *only* apply to
> > 2.6?  My motivation is clarity.  2.6 simplifies installation quite a bit
> but
> > it also deprecates a few functions and I'd rather not have too much "diff
> > docing" going on as it can confuse new users.
> I thought about this last night as I added strike through to some
> changed items.  I'm all for changing trunk and the 2.6 branch to match
> those realities.  Previous versions of documentation can live in their
> own branches, I think that dedicated version specific documentation is
> far better than 'diff docing'.
> Looking forward to it, Eli
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20120412/e1aeaf61/attachment.html
More information about the Geomoose-users mailing list
