[Geomoose-users] GeoMoose API: GeoMOOSE.turnLayerOn problem with multi map-source layers
Brent Fraser bfraser at geoanalytic.com
Mon Apr 16 15:08:23 EDT 2012
Dan,
   I'm using the GeoMoose API (v2.4 I think) in a JavaScript user
extension to  turn on a multi-mapsource Layer:
       GeoMOOSE.turnLayerOn("Image/image:Filler/all");
In geomoose.js, turnLayerOn calls changeLayerVisibility, where the
layerpath is split and the DOM is queried for each portion.  But those
portions are Map-Sources, not Layers, and therefor are not found.
So I changed the code to simply query on the original path (not the
portions), and it seems to work:
     changeLayerVisibility : function(layerPath, visibility) {
         var paths = this.splitPaths(layerPath);
         for(var p = 0; p < paths.length; p++) {
             var e = document.getElementById('catalog-'+paths[p]);
             if(!e && !Catalog.setLayerVisibility(paths[p], visibility)) {
                 OpenLayers.Console.log('Layer '+paths[p]+' does not
exist');
             } else if(e && e.checked != visibility) {
                 e.checked = visibility;
                 e.onclick();
         var e = document.getElementById('catalog-'+layerPath);
         if(!e && !Catalog.setLayerVisibility(layerPath, visibility)) {
             OpenLayers.Console.log('Layer '+layerPath+' does not exist');
             e.onclick();
If you think the above fix is valid, I'll file an Issue in Trac (I guess
we're still filing issues on v2.4), and put the fix in SVN.
Thanks!
Best Regards,
Brent Fraser
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20120416/8c0ddf34/attachment.html
More information about the Geomoose-users mailing list
