[Geomoose-users] Changes to mapserver-type layer handling in GM 2.6?
Johan Forsman Johan.Forsman at LA.GOV
Mon Apr 16 21:08:17 EDT 2012
Success!
The fastest method I could think of to test all layers was a bulk Find of "STATUS ON" and Replace with "GROUP 'all'" which indeed allows the layers to display as intended using <layer name="all"/> in the mapbook.
I think this topic needs to be documented front and center in the migration guide as it represents a fundamental change in the way the application works. I am sure there are many instances of legacy GM/MapServer  installations that may require significant retooling to work with the new version, especially if they are not configured to serve WMS already.
Thanks for the tips and for a really great product.
I am curious about Jim's "in the default case"  statement. Does this mean there is a case where the MapServer layers are *not* translated to WMS calls?
Incidentally, I may have discovered a few other items that may not be as intended. If they are not user error, where is appropriate to report them?
Thanks again,
Johan.
From: Bob Basques [mailto:Bob.Basques at ci.stpaul.mn.us]
Sent: Monday, April 16, 2012 3:07 PM
To: Jim Klassen; Johan Forsman
Cc: geomoose-users at lists.osgeo.org
Subject: Re: [Geomoose-users] Changes to mapserver-type layer handling in GM 2.6?
All (of you),
Just adding the desired layers to a GROUP called "all", should fix things (I think)
bobb
>>> Jim Klassen <klassen.js at gmail.com<mailto:klassen.js at gmail.com>> wrote:
It was intentional to migrate to using WMS over the MapServer specific calls in the default case as it eases interoperability with other servers and simplifies the code in many cases.
I don't think it was intentional to loose the layers=all trick (which was implemented inside MapServer not GeoMoose).  Do any of the suggestions in the MapServer ticket referenced by Bob work as a workaround for you?
While 2.6 is near to release, one of the bigger tasks left is finishing up documentation.  Thank you for testing and bring this to our attention.
On Apr 16, 2012, at 2:24 PM, Johan Forsman wrote:
> All:
> I am slowly migrating a GM 2.2 site with some minor customizations to 2.6 and am wondering if what I am observing with my mapserver layers is by design or an error on my part.
> On 2.6 it appears that all mapserver layers are requested as WMS which appears to result in
> 1) any mapserver-type layer returns an error if the map file does not at least contain something like 'ows_enable_request' '*', and
> 2) using the "all" parameter in the layer definition in the mapbook returns an error.
> For example, in the 2.2 environment I have a "roads" source defined in the mapbook very simply as such:
> <map-source name="roads_simple" type="mapserver" >
> <file>./sdwp/roads/webmaps_osm_lahwys.map</file>
> <layer name="all"/>
> <layer title="Roads" src="roads_simple/all" status="off" legend="true" show-legend="true" fade="false" unfade="false"/>
> The forwarded URL request is:
> http://oph-isb-gis01/cgi-bin/mapserv.exe?map=/mapserver/apps/geomoose2/maps//sdwp/roads/webmaps_osm_lahwys.map&layers=all&mode=map&mapext=-10879743+3088767+-9475743+4200267&imgext=-10879743+3088767+-9475743+4200267&map_size=1404+1111&imgx=702&imgy=555.5&imgxy=1404+1111
> The map file contains many scale-dependent line- and annotation layers and renders beautifully.
> In the 2.6 environment the same mapbook definition and mapfile results in this call:
> MAP=/mapserver/apps/geomoose26/maps//sdwp/roads/webmaps_osm_lahwys.map&FORMAT=image/png&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&LAYERS=all&SRS=EPSG%3A3857&BBOX=-10706687.23566,3214635.152984,-9648798.7643401,4074398.847016&WIDTH=865&HEIGHT=703
> which returns:
> <ServiceException code="LayerNotDefined">
> msWMSLoadGetMapParams(): WMS server error. Invalid layer(s) given in the LAYERS parameter.
> </ServiceException>
> I have unsuccessfully searched for documentation on this topic. Please advise.
> Thanks!
> Johan Forsman
> Geologist
> Engineering Services
> LDHH-OPH-CEHS
> 225.342.7309
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org<mailto:Geomoose-users at lists.osgeo.org>
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20120416/1d4278f6/attachment.html
More information about the Geomoose-users mailing list
