[Geomoose-users] problem setting up mapbook.xml in 2.6- projection issue
Dan Little danlittle at yahoo.com
Tue Apr 24 10:11:03 EDT 2012
Can you use Firebug or Firefox's "Page Info"'s "Media" tab to take a look at the calls that are being made?  There is probably an XML error that will indicate what is wrong.
>________________________________
> From: "Bistrais, Bob" <Bob.Bistrais at maine.gov>
>To: Dan Little <danlittle at yahoo.com>; Brian Fischer <bfischer at houstoneng.com>; geomoose-users at lists.osgeo.org
>Sent: Tuesday, April 24, 2012 8:54 AM
>Subject: RE: [Geomoose-users] problem setting up mapbook.xml in 2.6- projection issue
>Here is what I put in my new projection file.  I am in UTM 19N, which is EPSG:26919…
>Proj4js.defs["EPSG:26919"] = "+title=NAD83 / UTM zone19N +proj=utm +zone=19 +a=6378137.0 +b=6356752.3141403";
>-Still gets the pink screen.  If I use the epsg 26915 file, which is included (and very similar to my 26919), the map will draw without pink screen.
>Does anything look out of place here?
>From:Dan Little [mailto:danlittle at yahoo.com]
>Sent: Tuesday, April 24, 2012 9:23 AM
>To: Brian Fischer; Bistrais, Bob; geomoose-users at lists.osgeo.org
>Subject: Re: [Geomoose-users] problem setting up mapbook.xml in 2.6- projection issue
>YOU SHOULD NEVER CHANGE ANY SETTINGS IN "settings.ini"  .
>ONLY CHANGE SETTINGS IN "local_settings.ini"  ANY SETTING IN "local_settings.ini" WILL OVERRIDE A SETTING IN "settings.ini"
>You have been warned.
>>From:Brian Fischer <bfischer at houstoneng.com>
>>To: "Bistrais, Bob" <Bob.Bistrais at maine.gov>; "geomoose-users at lists.osgeo.org" <geomoose-users at lists.osgeo.org>
>>Sent: Tuesday, April 24, 2012 8:06 AM
>>There are a few more steps you have to take if you are going to change the projection.  Here is a basic list.
>>1)      Create a new Proj4js projection definition and put it in htdocs/projections
>>2)      In geomoose.html make sure you have a reference to that projection.  You should see a couple other in there now for 3857
>>3)      Change the projection in conf/settings.ini
>>4)      Change the projection in conf/mapbook.xml
>>This should be all you need to do.
>>Brian Fischer, CFM
>>GIS Manager
>>Houston Engineering, Inc.
>>O763.493.4522 | D 763.493.6664 | M 763.229.2734
>>From:geomoose-users-bounces at lists.osgeo.org [mailto:geomoose-users-bounces at lists.osgeo.org] On Behalf Of Bistrais, Bob
>>Sent: Monday, April 23, 2012 3:27 PM
>>To: geomoose-users at lists.osgeo.org
>>Subject: [Geomoose-users] problem setting up mapbook.xml in 2.6- projection issue
>>I downloaded the latest nightly to get familiar with release 2.6.  I’m afraid I didn’t get very far before the dreaded Pink Screen.  This happened when editing mapbook.xml, about line 11.  The parameter is the projection, EPSG:3857.  My data is in EPSG:26919.  If I change that line to 26919, the map screen goes pink.  I can’t find any errors in Firebug or the error.txt.  Any suggestions?
>>_______________________________________________
>>Geomoose-users mailing list
>>Geomoose-users at lists.osgeo.org
>>http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20120424/c0db198a/attachment-0001.html
More information about the Geomoose-users mailing list
