[Geomoose-users] problem setting up mapbook.xml in 2.6-projection issue
Bistrais, Bob Bob.Bistrais at maine.gov
Tue Apr 24 10:30:06 EDT 2012
Here’s the request for USGS maps:
BBOX-787590.97689331,4596412.4907104,1812490.9768933,5403587.5092896FORMATimage/pngHEIGHT330LAYERSDRGMAP/ms4w/apps/maptest/maps//demo/wms/usgs.mapREQUESTGetMapSERVICEWMSSRSEPSG:26919STYLESTRANSPARENTTRUEVERSION1.1.1WIDTH1063
From: geomoose-users-bounces at lists.osgeo.org [mailto:geomoose-users-bounces at lists.osgeo.org] On Behalf Of Bistrais, Bob
Sent: Tuesday, April 24, 2012 10:28 AM
To: Dan Little; Brian Fischer; geomoose-users at lists.osgeo.org
Subject: RE: [Geomoose-users] problem setting up mapbook.xml in 2.6-projection issue
Page Info/Media didn’t tell me much.  Firebug- here’s what the request was for the parcel layer:
http://localhost/cgi-bin/mapserv.exe?FORMAT=image%2Fpng%3Bbits%3D8&MAP=%2Fms4w%2Fapps%2Fmaptest%2Fmaps%2F%2Fdemo%2Fparcels%2Fparcels.map&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&LAYERS=parcels&SRS=EPSG%3A26919&BBOX=-787590.97689331,4596412.4907104,1812490.9768933,5403587.5092896&WIDTH=1063&HEIGHT=330
The BBOX looks a bit weird- notice that it starts with a negative number, in 26919 I’d expect all positive.  Also not able to turn on the USGS data, which I’d hoped would cover my area. (I get pink screen with the USGS data too)
Sent: Tuesday, April 24, 2012 10:11 AM
To: Bistrais, Bob; Brian Fischer; geomoose-users at lists.osgeo.org
Subject: Re: [Geomoose-users] problem setting up mapbook.xml in 2.6- projection issue
Can you use Firebug or Firefox's "Page Info"'s "Media" tab to take a look at the calls that are being made?  There is probably an XML error that will indicate what is wrong.
	To: Dan Little <danlittle at yahoo.com>; Brian Fischer <bfischer at houstoneng.com>; geomoose-users at lists.osgeo.org
	Sent: Tuesday, April 24, 2012 8:54 AM
	Subject: RE: [Geomoose-users] problem setting up mapbook.xml in 2.6- projection issue
	Here is what I put in my new projection file.  I am in UTM 19N, which is EPSG:26919…
	Proj4js.defs["EPSG:26919"] = "+title=NAD83 / UTM zone19N +proj=utm +zone=19 +a=6378137.0 +b=6356752.3141403";
	-Still gets the pink screen.  If I use the epsg 26915 file, which is included (and very similar to my 26919), the map will draw without pink screen.
	Does anything look out of place here?
	Sent: Tuesday, April 24, 2012 9:23 AM
	To: Brian Fischer; Bistrais, Bob; geomoose-users at lists.osgeo.org
	YOU SHOULD NEVER CHANGE ANY SETTINGS IN "settings.ini"  .
	ONLY CHANGE SETTINGS IN "local_settings.ini"  ANY SETTING IN "local_settings.ini" WILL OVERRIDE A SETTING IN "settings.ini"
	You have been warned.
		To: "Bistrais, Bob" <Bob.Bistrais at maine.gov>; "geomoose-users at lists.osgeo.org" <geomoose-users at lists.osgeo.org>
		Sent: Tuesday, April 24, 2012 8:06 AM
		There are a few more steps you have to take if you are going to change the projection.  Here is a basic list.
		1)      Create a new Proj4js projection definition and put it in htdocs/projections
		2)      In geomoose.html make sure you have a reference to that projection.  You should see a couple other in there now for 3857
		3)      Change the projection in conf/settings.ini
		4)      Change the projection in conf/mapbook.xml
		This should be all you need to do.
		Brian Fischer, CFM
		GIS Manager
		Houston Engineering, Inc.
		O 763.493.4522 | D 763.493.6664 | M 763.229.2734
		Sent: Monday, April 23, 2012 3:27 PM
		To: geomoose-users at lists.osgeo.org
		Subject: [Geomoose-users] problem setting up mapbook.xml in 2.6- projection issue
		I downloaded the latest nightly to get familiar with release 2.6.  I’m afraid I didn’t get very far before the dreaded Pink Screen.  This happened when editing mapbook.xml, about line 11.  The parameter is the projection, EPSG:3857.  My data is in EPSG:26919.  If I change that line to 26919, the map screen goes pink.  I can’t find any errors in Firebug or the error.txt.  Any suggestions?
		Geomoose-users mailing list
		Geomoose-users at lists.osgeo.org
		http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20120424/768ea443/attachment-0001.html
More information about the Geomoose-users mailing list
