[Geomoose-users] problem setting up mapbook.xml in 2.6- projection issue
Dan Little danlittle at yahoo.com
Tue Apr 24 11:08:05 EDT 2012
It may be included in geomoose_globals.map.  Make sure the file exists.
>________________________________
> From: "Bistrais, Bob" <Bob.Bistrais at maine.gov>
>To: Dan Little <danlittle at yahoo.com>; Brian Fischer <bfischer at houstoneng.com>; geomoose-users at lists.osgeo.org
>Sent: Tuesday, April 24, 2012 10:04 AM
>Subject: RE: [Geomoose-users] problem setting up mapbook.xml in 2.6- projection issue
>When opening in a new tab, here’s the error message:
>loadSymbolSet(): Unable to access file. (../../symbols/symbol.sym)
>However, the map file for this layer does not call for a symbol set, and I’m using just a simple polygon fill:
>    STYLE
>      COLOR 130 190 75
>      OUTLINECOLOR 0 0 0
>    END
>From:Dan Little [mailto:danlittle at yahoo.com]
>Sent: Tuesday, April 24, 2012 10:40 AM
>To: Bistrais, Bob; Brian Fischer; geomoose-users at lists.osgeo.org
>Subject: Re: [Geomoose-users] problem setting up mapbook.xml in 2.6- projection issue
>I can't open that link from here. :-)
>Can you open it in a different tab and see what error your are receiving? I agree the coordinates look wrong for a UTM projection.
>>From:"Bistrais, Bob" <Bob.Bistrais at maine.gov>
>>Sent: Tuesday, April 24, 2012 9:28 AM
>>Page Info/Media didn’t tell me much.  Firebug- here’s what the request was for the parcel layer:
>>http://localhost/cgi-bin/mapserv.exe?FORMAT=image%2Fpng%3Bbits%3D8&MAP=%2Fms4w%2Fapps%2Fmaptest%2Fmaps%2F%2Fdemo%2Fparcels%2Fparcels.map&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&LAYERS=parcels&SRS=EPSG%3A26919&BBOX=-787590.97689331,4596412.4907104,1812490.9768933,5403587.5092896&WIDTH=1063&HEIGHT=330
>>The BBOX looks a bit weird- notice that it starts with a negative number, in 26919 I’d expect all positive.  Also not able to turn on the USGS data, which I’d hoped would cover my area. (I get pink screen with the USGS data too)
>>Sent: Tuesday, April 24, 2012 10:11 AM
>>Can you use Firebug or Firefox's "Page Info"'s "Media" tab to take a look at the calls that are being made?  There is probably an XML error that will indicate what is wrong.
>>>Sent: Tuesday, April 24, 2012 8:54 AM
>>>Here is what I put in my new projection file.  I am in UTM 19N, which is EPSG:26919…
>>>Proj4js.defs["EPSG:26919"] = "+title=NAD83 / UTM zone19N +proj=utm +zone=19 +a=6378137.0 +b=6356752.3141403";
>>>-Still gets the pink screen.  If I use the epsg 26915 file, which is included (and very similar to my 26919), the map will draw without pink screen.
>>>Does anything look out of place here?
>>>Sent: Tuesday, April 24, 2012 9:23 AM
>>>To: Brian Fischer; Bistrais, Bob; geomoose-users at lists.osgeo.org
>>>YOU SHOULD NEVER CHANGE ANY SETTINGS IN "settings.ini"  .
>>>ONLY CHANGE SETTINGS IN "local_settings.ini"  ANY SETTING IN "local_settings.ini" WILL OVERRIDE A SETTING IN "settings.ini"
>>>You have been warned.
>>>>From:Brian Fischer <bfischer at houstoneng.com>
>>>>To: "Bistrais, Bob" <Bob.Bistrais at maine.gov>; "geomoose-users at lists.osgeo.org" <geomoose-users at lists.osgeo.org>
>>>>Sent: Tuesday, April 24, 2012 8:06 AM
>>>>There are a few more steps you have to take if you are going to change the projection.  Here is a basic list.
>>>>1)      Create a new Proj4js projection definition and put it in htdocs/projections
>>>>2)      In geomoose.html make sure you have a reference to that projection.  You should see a couple other in there now for 3857
>>>>3)      Change the projection in conf/settings.ini
>>>>4)      Change the projection in conf/mapbook.xml
>>>>This should be all you need to do.
>>>>Brian Fischer, CFM
>>>>GIS Manager
>>>>Houston Engineering, Inc.
>>>>O763.493.4522 | D 763.493.6664 | M 763.229.2734
>>>>From:geomoose-users-bounces at lists.osgeo.org [mailto:geomoose-users-bounces at lists.osgeo.org] On Behalf Of Bistrais, Bob
>>>>Sent: Monday, April 23, 2012 3:27 PM
>>>>To: geomoose-users at lists.osgeo.org
>>>>Subject: [Geomoose-users] problem setting up mapbook.xml in 2.6- projection issue
>>>>I downloaded the latest nightly to get familiar with release 2.6.  I’m afraid I didn’t get very far before the dreaded Pink Screen.  This happened when editing mapbook.xml, about line 11.  The parameter is the projection, EPSG:3857.  My data is in EPSG:26919.  If I change that line to 26919, the map screen goes pink.  I can’t find any errors in Firebug or the error.txt.  Any suggestions?
>>>>_______________________________________________
>>>>Geomoose-users mailing list
>>>>Geomoose-users at lists.osgeo.org
>>>>http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20120424/64c2d985/attachment-0001.html
More information about the Geomoose-users mailing list
