[Geomoose-users] Catalog->group - can't get GM to start with group folder closed
Bistrais, Bob Bob.Bistrais at maine.gov
Tue Aug 14 11:25:56 PDT 2012
Right, that's what I have, but the application doesn't start with the folders closed, although I have the expand parameter set to "false".
-----Original Message-----
Sent: Tuesday, August 14, 2012 2:16 PM
To: Ed Boesenberg
Cc: Bistrais, Bob; geomoose-users at lists.osgeo.org
Subject: Re: [Geomoose-users] Catalog->group - can't get GM to start with group folder closed
On Tue, Aug 14, 2012 at 10:57 AM, Ed Boesenberg <boesiii at yahoo.com> wrote:
> I just visited your test website and noticed clicking the folder icon
> has no effect.  It did not collapse.
If you are talking about this website,
http://mapservertest.maine.gov/basemap/index.html# the folder expansion/collapse works for me except that you must click the words of the group, not the folder.
Eli
> From: Bistrais, Bob [mailto:Bob.Bistrais at maine.gov]
> Sent: Tuesday, August 14, 2012 12:25 PM
> To: Ed Boesenberg
> Cc: geomoose-users at lists.osgeo.org
> Subject: RE: [Geomoose-users] Catalog->group - can't get GM to start
> Yes, tried that, but the application still starts with folders open.
> From: Ed Boesenberg [mailto:boesiii at yahoo.com]
> Sent: Tuesday, August 14, 2012 10:31 AM
> To: 'Jim Klassen'; Bistrais, Bob
> Bob,
> Have you tried to test it with only one small group of layers?
> Ed
> From: geomoose-users-bounces at lists.osgeo.org
> [mailto:geomoose-users-bounces at lists.osgeo.org] On Behalf Of Jim
> Klassen
> Sent: Tuesday, August 14, 2012 9:58 AM
> To: Bistrais, Bob
> Cc: geomoose-users at lists.osgeo.org List
> renderGroup in GeoMOOSE.Tab.Catalog
> But again... the same code (JavaScript, HTML, CSS) and the same
> mapbook in the same browser has to have the same results.  Unless you
> can come up with some meaningful difference between the original path
> that works and the supposedly identical copy that doesn't, I am at a
> complete loss as to how to help.  I'm starting to think your computer is just messing with you.
> Do you have any odd things going on in the web server where it is
> trying to add/change content on the fly?  I have see this in one case
> where they were using something server side to wrap all the pages with
> a common header that was breaking GeoMoose.
> On Aug 13, 2012, at 3:22 PM, Bistrais, Bob wrote:
> Well, I did the copy of GM, so I would guess that the file here were
> identical to the demo.  So are we hitting different files than
> expected?  If I do anything else to manipulate that mapbook.xml (such
> as change a title or something else minor), I see that change.  But,
> we're only talking about mapbook.xml.
> So, going on that, then we could infer that mapbook.xml is not hitting
> what it should.  What code is triggered by the <group> tag?
> From: Jim Klassen [mailto:klassen.js at gmail.com]
> Sent: Monday, August 13, 2012 4:11 PM
> To: Bistrais, Bob
> If the mapbook doesn't change, and it is the stock code base, GeoMoose
> doesn't have anything to display the catalog differently just because
> the base path changed so...
> * something is different in the "copy" GeoMoose
> * something is different in the mapbook being sent to the browser (and
> this was tested false)
> * the browser isn't receiving/rendering the files you (think you) have
> on the server.
> On Aug 13, 2012, at 2:24 PM, Bistrais, Bob wrote:
> Right, I created a new httpd file for it.
> No, I didn't change local_settings.ini in this example, although that
> would be done for a "real" application.  But, I don't think that
> should affect the group folders opening and closing either way.
> Sent: Monday, August 13, 2012 3:11 PM
> To: Bistrais, Bob
> What else did you do besides copying the directory
> (\ms4w\apps\geomoose2) under a new name (\ms44\apps\geomoose3)?  I
> just tried copying the directory and it is not enough for MS4W to
> pickup the new name - it doesn't find it at all.
> If I also copy and modify \ms4w\httpd.d\httpd_geomoose2_ms4w.conf to
> \ms4w\httpd.d\httpd_geomoose3_ms4w.conf and replace all occurrences
> within of geomoose2 with geomoose3, the demo works as expected.
> Presumably, \ms4w\apps\geomoose3\local_settings.ini should also be
> modified as well to use the copied version of the mapfiles, etc.
> On Aug 13, 2012, at 1:24 PM, Bistrais, Bob wrote:
> Just to be sure, I've just downloaded the latest GM 2.6 download.  I
> unzipped the demo app and it works normally.  Then I made a copy of it
> under a new name.  When I open this application, all folders are
> expanded.  They are both residing in the same ms4w/apps directory, the
> only difference is the application folder name.  Any ideas?
> Sent: Monday, August 13, 2012 1:16 PM
> To: Bistrais, Bob
> Resend: Message got too big for the list.
> There is something wrong with your GeoMoose install (as opposed to
> your mapbook).  I also checked and your getmapbook.php is returning
> the mapbook you sent in the email.  Are you sure you are using the
> released and/or latest version?
> I put your catalog into my app and it shows up like this to start.
> <image001.png>
> And the "nested" same groups show up when you click on them...
> <image002.png>
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users mailing list
