[Geomoose-users] Where does the map image go..?
Jonathan Moules jonathanmoules at warwickshire.gov.uk
Fri Aug 17 02:05:45 PDT 2012
Alternately, if you /do/ want your WMS images cached, you can deploy
something like MapCache. It seems to act as a kind of proxy for WMS images,
reducing the load on the MapServer. -
http://www.mapserver.org/trunk/en/mapcache/
On 16 August 2012 23:38, Jim Klassen <klassen.js at gmail.com> wrote:
> 1) GeoMoose doesn't render it.
> 2) MapServer, in most cases, send the rendered image directly to the
> browser and does not use a temp file.  Temp files would be created in case
> of a WMS source to MapServer or possibly some storage for some of the PHP
> based services.
> If you want to save a map render as a graphic, use firebug with the
> network tab enabled and save the image you want out of the list.
>  Alternatively the print service can print to an image.
>  On Aug 16, 2012, at 4:32 PM, Bistrais, Bob wrote:
>   I was curious as to where a generated map image goes when GeoMoose
> renders it?  I thought it was /ms4w/tmp/ms_tmp by default, and I have my
> image paths set as such, both in the ini files and the map files for the
> layers.  But I’m not finding any images in that directory.  Is this
> something to do with OpenLayers?  So if I wanted to grab a map image as a
> graphic, where would I find it?****
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us,  including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20120817/b01d6c0b/attachment.html>
More information about the Geomoose-users mailing list
