[Geomoose-users] Unable to view layer when zoom in to certain level
Lin, Joyce Joyce.Lin at pxd.com
Fri Dec 7 08:06:24 PST 2012
Tried the first option but didn't work.....
The layer stop drawing right around 1:5000000
From: Bistrais, Bob [mailto:Bob.Bistrais at maine.gov]
Sent: Friday, December 07, 2012 9:16 AM
To: Lin, Joyce; geomoose-users at lists.osgeo.org
Subject: RE: Unable to view layer when zoom in to certain level
Two thoughts come to mind-
First, try commenting out the Maxscaledenom lines in your map file.  Refresh the browser to see if that works.
Second, is it possible that you zoomed in so much that you can't see the proverbial forest through the trees?
From: geomoose-users-bounces at lists.osgeo.org<mailto:geomoose-users-bounces at lists.osgeo.org> [mailto:geomoose-users-bounces at lists.osgeo.org] On Behalf Of Lin, Joyce
Sent: Friday, December 07, 2012 9:54 AM
To: geomoose-users at lists.osgeo.org<mailto:geomoose-users at lists.osgeo.org>
Subject: [Geomoose-users] Unable to view layer when zoom in to certain level
Hello,
I hope someone can help me with this. I have a polygon layer which appears when I zoom out but disappear when I zoom in to certain level. I am new to GeoMoose. Any help is appreciated!!
The layer has original projection as "init=epsg:32040"
I am publishing to GeoMoose using Mapfile below. The Project in Mapbook.xml remained the same as default EPSG:3857
MAP
       NAME 'Lease'
       SIZE 800 650
       STATUS ON
       EXTENT  2016274.741485 176555.010138 2688771.295454 620600.467750
       UNITS FEET
       INCLUDE "/ms4w/apps/geomoose2/maps/geomoose_globals.map"
       PROJECTION
              'init=epsg:3857'
       END
       LEGEND
             STATUS ON
             LABEL
              TYPE TRUETYPE
              FONT vera_sans
              SIZE 8
              COLOR 0 0 0
             END
       END
       LAYER
              NAME Lease
              DATA './Lease.shp'
              STATUS ON
              TYPE POLYGON
              LABELITEM 'TRACT_NAME'
              LABELCACHE ON
              LABELMAXSCALE 20000
     PROJECTION
         'init=epsg:32040'
     END
              CLASS
                     NAME 'Lease'
                     STYLE
                           WIDTH 3
                           COLOR -1 -1 -1
                           OUTLINECOLOR 255 204 153
                           MAXSCALEDENOM 15000
                     END
                     STYLE
                           SIZE 1
                           COLOR -1 -1 -1
                     END
                     LABEL
                           TYPE TRUETYPE
                           FONT vera_sans
                           SIZE 8
                           ANTIALIAS TRUE
                           COLOR 0 0 0
                           OUTLINECOLOR 254 254 200
                           BUFFER 4
                           MINFEATURESIZE auto
                           PARTIALS FALSE
                           POSITION cc
                     END
              END
              METADATA
                     # drill-down identify service record.
                     'identify_record'    'templates/identify.html'
                     # query.php / "Search Lease" functionality.
                     'itemquery'   'templates/search_result.html'
                     'itemquery-filter'   '/.*[qstring].*/i'
                     'qstring_validation_pattern' '.'
                     # Feature reports are stored in the conf/feature_report directory.
                     'feature_report' 'parcel.xml'
                     'select_record'      'templates/select_result.html'
                     'select_header' 'templates/select_header.html'
                     'popups' 'Lease_popup.html'
              END
              TOLERANCE 0
         END
   CONFIG "MS_ERRORFILE" "/ms4w/tmp/ms_tmp/ms_error_Lease.txt"
   DEBUG 5
END ## end Map
Thank you,
Joyce Lin
Statement of Confidentiality:
This message may contain information that is privileged or confidential. If you receive this transmission in error, please notify the sender by reply e-mail and delete the message and any attachments.
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20121207/68c4cfab/attachment-0001.html>
More information about the Geomoose-users mailing list
