[Geomoose-users] invisible map after installing geomoose
Ed Boesenberg boesiii at yahoo.com
Fri Feb 10 10:44:31 EST 2012
Open geomoose_globals.map which is located at ms4w/apps/geomoose2/maps (not
sure what OS your using), near the bottom you will see IMAGETYPE agg/jpeg,
change to IMAGETYPE agg/png.
-----Original Message-----
From: Firdaus firdaus [mailto:alikomeini at gmail.com]
Sent: Thursday, February 09, 2012 5:36 PM
To: boesiii
Cc: geomoose-users at lists.osgeo.org
Subject: Re: [Geomoose-users] invisible map after installing geomoose
hallo boesiii
Thanks so much for your help. I've got error message from that address
loadOutputFormat(): General error message. OUTPUTFORMAT clause
references driver GD/JPEG, but this driver isn't configured
please help me how to solve it.
Thanks a lot for your help
regards
On Thu, Feb 9, 2012 at 7:03 PM, boesiii <boesiii at yahoo.com> wrote:
> Usually a pink screen means something is wrong with a MAP file.  To figure
> out what is going wrong I usually use Firefox.  To diagnose what is wrong,
> open the webpage in Firefox , go to Tools menu, then Page Info, then Media
> tab.  Once in the media tab, you will see a list of addresses, scroll down
> the list until you see something like
> "http://127.0.0.1/cgi-bin/mapserv.exe?map=%2Fms4w%2Fapps...", copy that
> entire address to the address bar and you should get an error message from
> MapServer telling you what's wrong with the MAP file.  Post the error
> message back here and I can try and help.
http://geomoose-users.964460.n3.nabble.com/Geomoose-users-invisible-map-afte
r-installing-geomoose-tp3722484p3730243.html
> Sent from the Geomoose-users mailing list archive at Nabble.com.
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
_______________________________
Firdaus
Sekjen YKU
http://www.kemaslahatan-ummat.org
http://firdausadnan.wordpress.com
More information about the Geomoose-users mailing list
