[Geomoose-users] Re: BookmarkTo​​Tab and Database Interaction
Dan Little danlittle at yahoo.com
Wed Feb 15 14:52:16 EST 2012
You'll need to make an extension.  If you look in the bookmark code itself, I believe there is a "GeoMOOSE.bookmark()" API function that returns the URL or partial URL needed to make a bookmark.
With the extension you can whip up some dynamic HTML to put that into a DIV in the middle of the screen and/or write that to a database for whatever reason you deem necessary to write it to a database.
>________________________________
> From: Aaban meetings <aabanatifbutt at gmail.com>
>To: danlittle at yahoo.com; "bfischer at houstoneng.com" <bfischer at houstoneng.com>; geomoose-users at lists.osgeo.org
>Sent: Wednesday, February 15, 2012 1:41 PM
>Subject: BookmarkTo​​Tab and Database Interaction
>Hi Dan, Brian and ALL
>Could you please guide me how to store the Bookmark URL to the database (or
>give me some guidance/hint plz), in order to store the state of the map
>permanently with its extents etc.
>Also is it possible to make the floating popup window for showing URL instead of
>showing inside the information tab.
>Guide me please
>Regards
>Aaban
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20120215/2236de25/attachment.html
More information about the Geomoose-users mailing list
