[Geomoose-users] Google API upgrade from V2 to V3
Brent Fraser bfraser at geoanalytic.com
Mon Feb 27 18:34:39 EST 2012
Dara,
As I recall using Google API v3 would require referencing the new API
javascript in GeoMoose.html (no key required with the new API).  It
would also require changing Geomoose's main.js (somewhere around line
430) from:
                 var google_translator = {
                     'physical' : G_PHYSICAL_MAP,
                     'streets' : null,
                     'hybrid' : G_HYBRID_MAP,
                     'satellite' : G_SATELLITE_MAP
to the new identifiers used (e.g. G_PHYSICAL_MAP is no longer used).
And I think it would require an upgrade to a more recent OpenLayers (and
that may cause other problems).
Best Regards,
Brent Fraser
On 2/27/2012 4:14 PM, Dara Olson wrote:
> Has anyone upgraded to the Google API version 3 for adding background
> layers in your GeoMoose app? If so, do you happen to have an example
> that you could share? I am assuming it would be the same setup as the
> GeoMoose documentation with V2 (except new key/script), but every time
> I attempt it crashes out the site. Any help would be greatly appreciated.
> Thanks!
> Dara
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20120227/96d9b7e5/attachment.html
More information about the Geomoose-users mailing list
