[Geomoose-users] Cant get the demo data to work
Brent Fraser bfraser at geoanalytic.com
Mon Jan 2 12:14:51 EST 2012
William,
  The fact that the buttons are rendered means the map book is being sent
by the sever-side scripting and parsed ok by the client-side javascript.
 Since  the map area is white and not a pink broken-image icon,
mapserver is returning an image (I think); it just isn't rendering any
the the data into it.  Typically this means the data is not accessible
(security, path problems, etc), or there's a projection problem (eg it
can't find EPSG:900913 in the epsg file).  I'd have to check past
emails, but I think you have the epsg problem....
Best Regards,
Brent Fraser
> Hi I was wondering if there is a read me or help file that can explain the
> default settings I should use when setting up geomoose.
> I unzipped all the packages to the c: drive on my computer and installed
> geomoose as well as the c: drive.
> I have checked and apache is working and so is map server
> When I go to http://localhost/geomoose2/geomoose.html
> it seems to work and geomoose opens but there is no data in there.
> The html template is there and so are the tools and buttons on the top as
> is
> the zoom and the ability to see the coordinates however....
> The screen is blank There is nothing in it.
> It seems that perhaps it is not reading the mapbook xml document.
> Is it an issue with perhaps using python 2.4 as opposed to 2.5  ?
> Any help would be awesome.
> It seems like a great programme once I can get it to work. The HTML side
> of
> things seems to work but just getting the scripts to actually start
> loading
> the data are not working.
> Here is print screen as well
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users mailing list
