[Geomoose-users] Cant get the demo data to work
Brent Fraser bfraser at geoanalytic.com
Mon Jan 16 18:41:35 EST 2012
William,
Did you install "GeoMoose 2.4 for MS4W" or "GeoMoose 2.4 for MS4W - Web
Mercator"?
Best Regards,
Brent Fraser
On 1/16/2012 4:22 PM, William Lavell wrote:
> Hi
> o/s is windows
> MS4w version = MS4W 2.3.1.
> GeoMOOSE 2.4 for MS4W - Web Mercator Demo
> Firefox 9.0.1
> -----Original Message-----
> From: Brent Fraser [mailto:bfraser at geoanalytic.com]
> Sent: Saturday, January 14, 2012 8:49 AM
> To: William Lavell
> Cc: GeoMOOSE Users List
> Subject: Re: [Geomoose-users] Cant get the demo data to work
>     I think Eli gave some good advice in reply to your email on Jan 3.
> But to make sure I'm on the right track to solve your problem, I need some more info on your configuration:
> Server O/S:     ?
> MS4W version:      ?
> GeoMoose:    v2.4
> Browser:    Firefox v?
> Thanks!
> Best Regards,
> Brent Fraser
> On 1/13/2012 4:25 PM, William Lavell wrote:
>> Hi so how do you suppose I can begin to solve this issue.  Where
>> should the correct projection be? It is odd how I installed it exactly
>> as the documentation states I should but nothing seems to be coming.
>> Where should my data be located?  How can I find the EPSG file?
>> Sent: Monday, January 02, 2012 9:15 AM
>> To: William Lavell
>> Cc: geomoose-users at lists.osgeo.org
>> William,
>>     The fact that the buttons are rendered means the map book is being
>> sent by the sever-side scripting and parsed ok by the client-side javascript.
>>    Since  the map area is white and not a pink broken-image icon,
>> mapserver is returning an image (I think); it just isn't rendering any
>> the the data into it.  Typically this means the data is not accessible
>> (security, path problems, etc), or there's a projection problem (eg it
>> can't find
>> EPSG:900913 in the epsg file).  I'd have to check past emails, but I
>> think you have the epsg problem....
>> Best Regards,
>> Brent Fraser
>>> Hi I was wondering if there is a read me or help file that can
>>> explain the default settings I should use when setting up geomoose.
>>> I unzipped all the packages to the c: drive on my computer and
>>> installed geomoose as well as the c: drive.
>>> I have checked and apache is working and so is map server
>>> When I go to http://localhost/geomoose2/geomoose.html
>>> it seems to work and geomoose opens but there is no data in there.
>>> The html template is there and so are the tools and buttons on the
>>> top as is the zoom and the ability to see the coordinates however....
>>> The screen is blank There is nothing in it.
>>> It seems that perhaps it is not reading the mapbook xml document.
>>> Is it an issue with perhaps using python 2.4 as opposed to 2.5  ?
>>> Any help would be awesome.
>>> It seems like a great programme once I can get it to work. The HTML
>>> side of things seems to work but just getting the scripts to actually
>>> start loading the data are not working.
>>> Here is print screen as well
>>> Geomoose-users mailing list
>>> Geomoose-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users mailing list
