[Geomoose-users] How to use multiple mapbook?
maddqc qc_mad at hotmail.com
Tue Jan 17 08:57:07 EST 2012
Thanks for your quick reply M. Fraser.
Right after posting this message, I've tried something else, because my
problem is a  bit more complex then that.
I have found that in the config.php there is a function "GetMapBook". So,
when this function is called, I'm catching in the session a variable that
contain the right name of the mapbook to load.
So the new function GetMapBook is now like this:
function getMapbook()
	global $CONFIGURATION;
	$mapbook = new DOMDocument();
	$mapbook->load('../../conf/'.$_SESSION['id_org'].'_mapbook_projet.xml');
	return $mapbook;
And we have a mapbook file for each different type of user. That way, we can
bypass the default value in the settings.ini
I must say, that I use an AJAX call in the main function of the file
compiled.js to set my variable $_SESSION['id_org'].
What do you think of that solution?
Thanks again!!!
View this message in context: http://geomoose-users.964460.n3.nabble.com/How-to-use-multiple-mapbook-tp3664006p3666147.html
Sent from the Geomoose-users mailing list archive at Nabble.com.
More information about the Geomoose-users mailing list
