[Geomoose-users] Feature Editor Adding Point, Line, Polygon Problems
sana butt sanaatifbutt85 at gmail.com
Sun Jan 29 05:11:35 EST 2012
Hi Brent
I have added polygon feature and its working, Now I have added point using
the same criteria available at feature editor guide, but its not working.
Could you please test the URL:
http://216.58.43.167/geomoose2/geomoose.html
and add point.
What I have done so far:
CREATE TABLE test_points
  feature_id integer NOT NULL,
  attribute1 character varying(100),
  attribute2 character varying(100),
  wkb_geometry geometry,
  CONSTRAINT pk_test_points PRIMARY KEY (feature_id)
CREATE SEQUENCE test_points_seq;
insert into geometry_columns values ('', 'public', 'test_points',
'wkb_geometry', 2, 24, 'GEOMETRY');
and follow the instructions available in feature editor guide.
I got this error in firefox.
URL:
http://216.58.43.167/cgi-bin/mapserv.exe?map=%2Fms4w%2Fapps%2Fgeomoose2%2Fmaps%2F%2Fdevelopment%2Ftest_points%2Ftest_points.map&layers=points&mode=map&mapext=457196.607656+4917749.476731+517604.607656+4948205.476731&imgext=457196.607656+4917749.476731+517604.607656+4948205.476731&map_size=2517+1269&imgx=1258.5&imgy=634.5&imgxy=2517+1269
Error:
msDrawMap(): Image handling error. Failed to draw layer named 'points'.
prepare_database(): Query error. Error declaring cursor: ERROR: column "id"
does not exist LINE 1: ...b_geometry)),'NDR'),feature_id::text from (select
id as feat... ^ With query string: DECLARE mycursor BINARY CURSOR FOR
SELECT
asbinary(force_collection(force_2d(wkb_geometry)),'NDR'),feature_id::text
from (select id as feature_id, attribute1, attribute2, astext(wkb_geometry)
as wkt_geometry, wkb_geometry from test_points) as mytable WHERE
wkb_geometry && setSRID('BOX3D(457184.796930448
4917749.476731,517616.418381552 4948205.476731)'::BOX3D, 24 )
I dont know, where I made mistake in creating table, etc.
Could you please help me solving this issue
Regards
Sana
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20120129/77ad7943/attachment.html
More information about the Geomoose-users mailing list
