[Geomoose-users] Re: Feature Editor: Delete Geomatery, Polygon, Line, Point
Brent Fraser bfraser at geoanalytic.com
Mon Jan 30 10:06:29 EST 2012
Your Identify service for points is not working (returns "Unhandled
request return Internal Server Error") so I can't test the deleting of a
point on your system.
Best Regards,
Brent Fraser
On 1/30/2012 4:46 AM, sana butt wrote:
> Hi Brent
> Could you please guide me in making delete service too.
> What I did sofar:
> Step 1)
> <service name="modify_point">
> <url>php/editor.php</url>
> <step type='spatial' name='feature:wkb_geometry' line='false'
> polygon='false' point='true' default='point' edit-point='true'>
> <input type="hidden" name="op" value="update"/>
> <input type="hidden" name="table" value="test_points"/>
> <input type="hidden" name="feature:feature_id"/>
> <input type="user" name="feature:attribute1" title="attribute1:"/>
> <input type="user" name="feature:attribute2" title="attribute2:"/>
> </step>
> </service>
> <service name="delete_point">
> <step type='input'>
> <input type="hidden" name="op" value="delete"/>
> </step>
> </service>
> Step 2)
> <tool name="delete_point" title="Delete Point" type="service"
> service="delete_point"/> (gives me message of "No Feature ID specified
> to delete." when I click tool button)
> Step 3) identify.html
> <tr bgcolor="#AA55AA">
> <td>Feature:</td><td>[feature_id]</td>
> </tr>
> <tr>
> <td>Attribute1:</td><td>[attribute1]</td>
> </tr>
> <tr>
> <td>
> <a href="javascript:GeoMOOSE.startService('modify_point',
> {'feature:id' : '[feature_id]','feature:wkb_geometry' :
> '[wkt_geometry]', 'feature:attribute1' : '[attribute1]',
> 'feature:attribute2' : '[attribute2]'})">Edit</a>
> </td>
> <td>
> <a href="javascript:if(confirm('Are you sure you want to delete
> this?')) { GeoMOOSE.startService('delete_point', {'feature:id' :
> '[feature_id]'}); }">Delete</a>
> </td>
> </tr>
> Now what step I need to perform, e.g.,  my identify.html is not
> recognizing (i guess so) to start the service of modify_point or
> delete_point etc. My identify.html files are stored at the path :
> geomoose2\maps\development\  (these directories also contain map files
> e.g., test_polygons.map file etc.)
> Kindly check the URL and files path from here:
> http://216.58.43.167/geomoose2/
> http://216.58.43.167/geomoose2/geomoose.html
> Regards
> Sana
More information about the Geomoose-users mailing list
