[Geomoose-users] mapfile returned as WMS
Jim Klassen klassen.js at gmail.com
Thu Jul 5 15:06:13 PDT 2012
I see this is rather buried and sparsely covered in the documentation, but GeoMoose is using WMS calls to MapServer now in 2.6 instead of making mode=map calls.  As such, you need to enable WMS in your map file.
Search for wms_enable_request on the following page for how to enable this in your mapfile(s):
http://mapserver.org/ogc/wms_server.html
On Jul 5, 2012, at 4:13 PM, Matej Mailing wrote:
> Hi,
> I am deploying a freshly downloaded 2.6 version and have an issue
> where the requested Mapserver URL is:
> http://SERVER_IP/cgi-bin/mapserv?MAP=mapfile.map&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&LAYERS=Test&SRS=EPSG%3A4326&BBOX=258481.81142578,44453.71465683,845518.18857422,235546.28534317&WIDTH=1920&HEIGHT=625
> My question is: why is the service WMS selected, even though I have a
> source declared like:
>        <map-source name="test" type="mapserver" reference="true">
>                <file>mapfile.map</file>
>                <layer name="Test" status="on"/>
>        </map-source>
> Also when I compare the Mapserver request to the previous GM version,
> there was a mode=map parameter in the Mapserver request.
> Now when I directly copy the URL that is open by the GM in the
> browser, I get XML as a return that contains text:
> "msWMSDispatch(): WMS server error. WMS request not enabled. Check
> wms/ows_enable_request settings."
> I am pretty lost here and any ideas of solving the issue are very welcome :-)
> Thanks,
> Matej
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users mailing list
