[Geomoose-users] GeoMoose Catalog- groups and sub-groups- on and off
    Brent Fraser
    bfraser at geoanalytic.com
    Fri Jul  6 08:08:31 PDT 2012
Bob,
   If you are comfortable with JavaScript, you could use GeoMoose's
Custom Input Types (http://www.geomoose.org/howto/add_input_types.html)
and have a layer entry in the catalog "Image index".  The code
referenced by the Custom Input Type could get the layer name of the
currently viewed Ortho and turn on the index (or something like that)...
Best Regards,
Brent Fraser
On 7/6/2012 8:51 AM, Bistrais, Bob wrote:
> Hmm, not exactly what I had in mind- For each subgroup, I wanted to be
> able to turn the orthos and the index on/off individually, but have
> both turned off if a different group is viewed.  For instance, I want
> to look at Orthos2011 imagery, so I click it.  I also want to be able
> to turn the Orthos2011 Index layer on or off, still see the imagery.
> Now, I want to look at Orthos2009 imagery, and maybe its index.  So we
> want to make sure Orthos2011 AND its index are turned off.  In other
> words, an image layer and its index are multiple=true, but each
> imagery category (2011, 2009, etc) whould be multiple = false.
> That does give me a possible idea, though.  If I leave everything as
> multiple=false, then have two catalog entries for each image layer-
> one that shows imagery only, one that shows imagery with index layer
> on top.  That might work...
> *From:*Brent Fraser [mailto:bfraser at geoanalytic.com]
> *Sent:* Friday, July 06, 2012 10:39 AM
> *To:* Bistrais, Bob
> *Cc:* geomoose-users at lists.osgeo.org
> *Subject:* Re: [Geomoose-users] GeoMoose Catalog- groups and
> Bob,
>   GeoMoose will handle it for you.  Put the layers in a <group> with a
> multiple="false" tag:
> <catalog>
>     <group title="Orthos" expand="false" multiple="false">
>         <layer
>     </group>
> </catalog>
> Best Regards,
> Brent Fraser
> On 7/6/2012 8:27 AM, Bistrais, Bob wrote:
>     I'm putting together an application which has a number of
>     orthoimagery layers.  For each of these image layers, there is a
>     corresponding index layer (i.e., a grid where each cell
>     corresponds to each individual image). So I took all the image
>     layers and put them in the <catalog> section as a group,
>     multiple=false.
>     Now, for each image layer, I want to create another group- each of
>     these groups will have an image layer and an index layer.  I want
>     to allow multiple=true, so you can turn the photos and the index
>     on or off at will.  So far, so good.
>     Here's the hitch:
>     If I decide to select another ortho layer (subgroup, with images
>     and index), I want to turn off the previously selected group.
>     This does not happen when I try to select a new group.  How can I
>     do this?  Not sure if this all makes sense, I'd be happy to
>     explain further.
>     _______________________________________________
>     Geomoose-users mailing list
>     Geomoose-users at lists.osgeo.org  <mailto:Geomoose-users at lists.osgeo.org>
>     http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20120706/ec983fde/attachment.html>
More information about the Geomoose-users
