[Geomoose-users] Search/Select from Dojo Windows
Dan Little danlittle at yahoo.com
Wed Jul 11 03:42:30 PDT 2012
Right now it's "roll your own."
The Docs are really more for users than developers.  That is unfortunate but those willing to write the documentation are not always those writing the code.
There are some basic rules:
 1. Try to use the "GeoMOOSE." API.  Those are the functions listed in geomoose/geomoose.js, as they are the ones that we try to keep supported through the versions.
 2. We are using Dojo 1.6.1.  All GeoMOOSE 2.6 versions will use that version of Dojo as might GeoMOOSE 2.8.  Switching to Dojo 1.7 is a sizable undertaking as they have changed the build system and to an AMD loader.
 3. You are maintaining it.  Please have a good familiarity with Firebug or the WebKit diagnostic console before starting.  I and others will try to be as helpful as possible but there are limitations.
>________________________________
> From: Matej Mailing <mailing at tam.si>
>To: GeoMOOSE Users List <geomoose-users at lists.osgeo.org>
>Sent: Sunday, July 8, 2012 4:39 PM
>Subject: [Geomoose-users]  Search/Select from Dojo Windows
>Yes, it's a pretty powerful thing. Have to work more with it. Are
>there any docs about the service integration with Dojo already on the
>GM site so I can have them for a start?
>Thanks,
>Matej
>2012/7/7 Dan Little <danlittle at yahoo.com>:
>> User extensions! :-)
>> Feel free to exercise Dojo.
>> Sent: Friday, July 6, 2012 6:18 AM
>> Hi,
>> since Dojo is available in GM, I was thinking of using it to get the
>> search parameters or to select particular parcels. Side window has
>> limited width and for example in a Dojo window, you could list a
>> number of parcels and then when a user clicked "Jump to" on some,
>> zooming to it should occur. What would be the best way to achieve
>> this?
>> TIA,
>> Matej
>> Geomoose-users mailing list
>> Geomoose-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20120711/4af36065/attachment-0001.html>
More information about the Geomoose-users mailing list
