[Geomoose-users] TMS layers in GeoMoose 2.2
Jim Klassen
klassen.js at gmail.com
Thu Jun 7 08:19:47 PDT 2012
I haven't tried a TMS that isn't in the 3857 projection. I wouldn't be surprised if this isn't easily supported before 2.6. I know when I was trying out different TMS parameters in 2.4 that I needed to create a custom layer type to deal with it. For more standard TMS layers, I used the "xyz" type in 2.4.
I would recommend you use WMS to access your MapCache tiles if you are using non-web-mercator projections in GeoMoose 2.2. MapCache will still use any cached tiles to assemble the result. GeoMoose 2.6 (along with the newer OpenLayers version) at least has the potential to make non-standard TMS configurations work from the mapbook. (Although I suspect the code for the TMS map source will need to be extended… it will at least be possible to do this in a sane manner).
I haven't tried WMTS. I suspect it misses the biggest reason of having tiles in the first place… the fact that they can be cached using standard HTTP caches and CDNs that aren't geo-spatially aware. Tiles aren't so much for your server as they are for the network. Also, make sure you have HTTP1.1 Keep-Alives active on your web servers. Assuming that your data and map files are organized so that MapServer can operate efficiently, without Keep-Alives, the extra network overhead from the many requests for tiles will overwhelm any speedup from having everything cached.
Jim Klassen
On Jun 7, 2012, at 9:54 AM, Mark Volz wrote:
> Hello,
> I am trying to figure out how to set up a TMS layer for geoMOOSE. If anyone knows what parameters are needed let me know.
> Here is an example request from the mapcache TMS demo: http://10.0.8.116/mapcache/tms/1.0.0/MNSOUTH11@UTM15/0/0/1.jpg
> Also, if WMTS or something else will work better for GeoMOOSE 2.2 / 2.6 let me know.
> Thank You!
> Mark Volz
> GIS Specialist
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20120607/24a1d630/attachment.html>
More information about the Geomoose-users
