[Geomoose-users] Adding Layer with EPSG:4326
    Ed Boesenberg
    boesiii at yahoo.com
    Fri Mar 16 08:13:12 EDT 2012
Try adding more scale factors to the scales list.
If you are changing the projection, have you followed the procedure at http://geomoose.org/docs/projections.html?
Ed
From: geomoose-users-bounces at lists.osgeo.org [mailto:geomoose-users-bounces at lists.osgeo.org] On Behalf Of zery.sp at gmail.com
Sent: Friday, March 16, 2012 6:44 AM
To: geomoose-users at lists.osgeo.org
Subject: [Geomoose-users] Adding Layer with EPSG:4326
I'm a new comer, I'm aware that this might have been asked many times, but please let me ask one more time. I'm using GM 2.2 with MS4W, I have disabled all the built in layers and background map, then I add my own mapserver layer and configure everything according to the documentation and some archive post here. The layer is in longlat projection. The map is shown in GM but the problem is I can't get zoom-in or out at the current view.
I believe it is something to do with scales and projection system, but I really can't figure out what to do.
When the map is shown the scales number in the bottom of page is showing 1:15xxxxx (notice that its about 1,5million). And the initial extent is not corresponding to the initial extent value I've set in mapbook.xml. And the max_extent either.
I change ground units from "m" to "dd" and back to "m" nothings happen.
I add ".2" in scales and it only make my map view bigger but still can't do zooming.
So please can someone help me what to do to fixed all this?
Regards,
Zery
Powered by Telkomsel BlackBerry®
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20120316/6b1bf7df/attachment.html
More information about the Geomoose-users
