[Geomoose-users] Jump To and Change Layer visibility
Zery zery.sp at gmail.com
Mon Mar 19 10:25:55 EDT 2012
  On 3/19/2012 10:00 PM, Eli Adam wrote:
> For many OSGeo projects (and others too), you can search the lists
> through nabble, http://osgeo-org.1560.n6.nabble.com/ (or
> http://www.nabble.com/ and click on OSGeo).  I'll try to make a note
> in the documentation about that.
Thanks for the links, it saves me hundred of clicks.
> This documentation has some details specific to some previous Oregon
> customizations.  Probably the best documentation for setup (and
> specifically zoom to) would be
> http://geomoose.org/docs/configuration.html#zoomto
> The "Jump To"/"Zoom To" function is to have spatial bookmarks.  You
> click on something (like a city name) and it zooms to display the
> spatial extent of that city.  It looks like you config has mixed
> projections.  You'll want to use the projection of your
> http://geomoose.org/docs/configuration.html#projection also in
> settings.ini file.  When you say nothing happens, does that mean that
> you map doesn't have the 'Jump To:' dropdown with Area1,2,3?  Or that
> clicking on those doesn't change the extent?
I'm sure I have read those link many times, from the example it has
groups of zoom to,
'Communities':['static:rural',[
['Arch Cape',[7317188,796289.34000000,7322479,805653]],
['Bradwood',[7455671,934752.42000000,7459244,937982]],
['Cannon Beach Junction',[7329878,845037,7334717,850082]]]]
when I try to use groups on my Jump To function it doesn't change the
extent and it only shows 'Communities' but Arch Cape and the others are
not. How did this groups really works?
> There is nothing preconfigured to change layer visibility with zoom to
> extents (unless that also changed scales and there was scale
> dependencies on the layers).
> HTH, Eli
Thank you Eli, I've learned recently that it was a MapFile scale
configuration that did the tricks.
I know this had been talk alot but here it goes, I hope someone out
there had the time to wrote a comprehensive step-by-step manual. Maybe
with an example project building webgis with geomoose. What to do first,
where to go next, which file had to be edited, what is the use of one
function, how to track an error, etc (too much huh :-) )
My experience on using geomoose for the first time and as not a webgis
specialities, using the available documentation really had make me
almost going nowhere. I'm sorry for throwing so much demand.
Regards,
Zery
More information about the Geomoose-users mailing list
