[Geomoose-users] Measure tool
Mark Volz MarkVolz at co.lyon.mn.us
Thu Mar 22 17:24:37 EDT 2012
Hello,
You might want to check your ground units in mapbook.xml
<param name="ground_units">ft</param>
Mark Volz
GIS Specialist
-----Original Message-----
From: geomoose-users-bounces at lists.osgeo.org [mailto:geomoose-users-bounces at lists.osgeo.org] On Behalf Of neslonotnilc
Sent: Thursday, March 22, 2012 4:09 PM
To: geomoose-users at lists.osgeo.org
Subject: [Geomoose-users] Measure tool
I am doing a new GeoMoose 2.2 installation on the MS4W 2.3.1 package.  I followed the projection instructions and installed a layer on projection ESRI:102743.  While I was testing I noticed the measure tool is not showing the correct distance.  I measured one city block at 536 ft on ArcMap, and on Geomoose I measured the same block and it said it was 1836 ft.  I have changed to several different projections and still get the same measure tool result after clearing the web cache each time.  There is probably some switch for the measure tool that I am missing.  Any ideas?  Thanks.
View this message in context: http://geomoose-users.964460.n3.nabble.com/Measure-tool-tp3849820p3849820.html
Sent from the Geomoose-users mailing list archive at Nabble.com.
Geomoose-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users mailing list
