[Geomoose-users] Identify tool - How to?
Bistrais, Bob Bob.Bistrais at maine.gov
Wed Mar 28 12:24:59 EDT 2012
Are you getting anything at all for that layer?  For instance, are the
results showing the title of the layer?  Is the layer on, visible, and
within scale range when you try to identify it?
-----Original Message-----
[mailto:geomoose-users-bounces at lists.osgeo.org] On Behalf Of Clinton
Olsen
Sent: Wednesday, March 28, 2012 12:18 PM
To: Bistrais, Bob; 'Zery'
Cc: geomoose-users at lists.osgeo.org
Subject: RE: [Geomoose-users] Identify tool - How to?
Thanks for the suggestion.  This is what I have in the mapfile metadata
section.  I am not sure if I used it right or not.  It still does not
work
after I added fields to my mapfile metadata.
METADATA
	'identify_record' 'identify_placenames.html'
	"fields"
	"NAME:NAME"
END
From: Bistrais, Bob [mailto:Bob.Bistrais at maine.gov]
Sent: Wednesday, March 28, 2012 9:50 AM
To: Clinton Olsen; Zery
You don't have the "fields" item in your metadata section.  Example
(belongs
in Metadata section of map file):
"fields"
"FID:FID,RDNAME:RDNAME,L_ADD_FROM:L_ADD_FROM,R_ADD_FROM:R_ADD_FROM"
Olsen
Sent: Wednesday, March 28, 2012 11:16 AM
To: 'Zery'
I checked and my template file is in the same folder as the mapfile.
Thanks
for the suggestion.
Sent: Tuesday, March 27, 2012 4:07 PM
To: neslonotnilc
Subject: Re: [Geomoose-users] Identify tool - How to?
I have the same issue before, first thing i would asked to you is :
(this is my stupid mistake) are your identify template file
"identify_placenames.html" in the same folder with your  mapfile?
Then, make sure there is no missed typed names, attribute column, etc.
Regards,
Zery
On 3/28/2012 12:04 AM, neslonotnilc wrote:
> I have been troubleshooting the identify feature for my geomoose
application.
> I can get some of the layers to identify, and other layers won't show
> up when I try to identify them.  I have looked on geomoose.org for a
> How To for the identify tool so I could make sure I was doing
> everything required for my mapfile, mapbook.xml, and my template but
there
doesn't seem to be one.
> Where can I go to get more information on this feature?  I think if I
> can get some pointers on what I need to do then I can make all the
> other layers be identifiable.
> This is one of the layers that will not identify.  I have a layer
> named placenames.  In the mapbook.xml I have it referenced as:
> ESRI:102743
> <map-source name="placenames" type="mapserver" reference="true">
> <file>./interactive_maps/placenames/placenames.map</file>
> <layer name="placenames"/>
> </map-source>
> <layer title="Place Names" src="placenames/placenames" status="on"
> popups="false" minscale="0" maxscale="150000" metadata="false">
> </layer>
> ---Mapfile ---
> MAP
> NAME 'placenames'
> SIZE 800 650
> STATUS ON
> EXTENT  1426801 6519737 2267577 7175357 UNITS FEET #FONTSET
> '../fonts/fontset.list'
> #SYMBOLSET '../symbols/symbol.sym'
> TRANSPARENT TRUE
> IMAGETYPE PNG
> INCLUDE "../../geomoose_globals.map"
> WEB
> INCLUDE "../../temp_directory.map"
> END
> PROJECTION
> 'init=esri:102743'
> end
> LEGEND
> STATUS ON
> END
> LAYER
> NAME "placenames"
> DATA "placenames.shp"
> STATUS DEFAULT
> TYPE POINT
> LABELITEM 'NAME'
> LABELCACHE ON
> LABELMAXSCALE 100000
> PROJECTION
> 'init=esri:102743'
> end
> CLASS
> NAME 'Attractions'
> STYLE
> SYMBOL 'STAR'
> COLOR 255 102 51
> OUTLINECOLOR 0 0 0
> SIZE 8
> END
> LABEL
> TYPE TRUETYPE
> FONT vera_sans-bold
> SIZE 8
> ANTIALIAS TRUE
> COLOR 0 0 0
> OUTLINECOLOR 254 254 254
> BUFFER 4
> PARTIALS FALSE
> POSITION auto
> SIZE 7
> END
> END
> METADATA
> END
> END
> END
> ---Identify results---
> <results><script/><html></html></results>
> http://geomoose-users.964460.n3.nabble.com/Identify-tool-How-to-tp3861
> 865p3861865.html Sent from the Geomoose-users mailing list archive at
> Nabble.com.
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users mailing list
