[Geomoose-users] PHP error
    Dan Little
    danlittle at yahoo.com
    Thu Mar 29 12:47:02 EDT 2012
I really couldn't tell you on Windows.  You may actually be hitting a process limit.  The core of the problem resides in the PHP implementation but this will be getting into a realm in which I'm mostly unfamiliar.
>________________________________
> From: Michael Neimeyer <mike.neimeyer at flatrockgeo.com>
>To: Dan Little <danlittle at yahoo.com>
>Cc: "geomoose-users at lists.osgeo.org" <geomoose-users at lists.osgeo.org>
>Sent: Thursday, March 29, 2012 9:41 AM
>Subject: Re: [Geomoose-users] PHP error
>Like I said, it used to work just fine with the current settings and then all of a sudden stopped working.
>The parcels dataset has about 10000 records.  What would you recommend changing the memory settings too?
>Mike
>Mike Neimeyer
>GIS Project Manager
>Flat Rock Geographics
>2434 Virginia Circle
>Roseville, MN. 55113
>(M) 612.695.7325
>On Thu, Mar 29, 2012 at 9:22 AM, Dan Little <danlittle at yahoo.com> wrote:
>I've usually changed the PHP memory settings, not sure where else to look on that one.
>>Is this parcel file particularly large or complex?
>>>To: geomoose-users at lists.osgeo.org
>>>Sent: Wednesday, March 28, 2012 11:26 AM
>>>Subject: [Geomoose-users] PHP error
>>>I am getting a fatal error when running a URL call (call=search_by_pin&qstring=243024230015) in GeoMoose.  It was working well but now times out:
>>>Fatal error: Allowed memory size of 134217728 bytes exhausted (tried to
allocate 5 bytes) in C:\ms4w\apps\geomoose2\htdocs\php\query.php on line 331
>>>I tried making changes to the settings in the Apache php.ini file to no avail.  Any thoughts on this issue?
>>>Thanks!
>>>Mike
>>>Mike Neimeyer
>>>GIS Project Manager
>>>(M) 612.695.7325
>>>_______________________________________________
>>>Geomoose-users mailing list
>>>Geomoose-users at lists.osgeo.org
>>>http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20120329/7f5d26b1/attachment.html
More information about the Geomoose-users
