[Geomoose-users] PHP error
Michael Neimeyer mike.neimeyer at flatrockgeo.com
Thu Mar 29 15:56:06 EDT 2012
I tried turning off the parcels layer and performing the call but
unfortunately the same results happened.
Thanks.  Any other thoughts?
*Mike Neimeyer
GIS Project Manager*
*Flat Rock Geographics
2434 Virginia Circle
Roseville, MN. 55113
(M) 612.695.7325
mike.neimeyer at flatrockgeo.com <mike at gisrangers.com>*
On Thu, Mar 29, 2012 at 1:02 PM, Ed Boesenberg <boesiii at yahoo.com> wrote:
> Does it work when you turn off the parcel layer or some of the other
> layers?****
> *From:* geomoose-users-bounces at lists.osgeo.org [mailto:
> geomoose-users-bounces at lists.osgeo.org] *On Behalf Of *Michael Neimeyer
> *Sent:* Thursday, March 29, 2012 10:41 AM
> *To:* Dan Little
> *Cc:* geomoose-users at lists.osgeo.org
> *Subject:* Re: [Geomoose-users] PHP error****
> Like I said, it used to work just fine with the current settings and then
> all of a sudden stopped working.  ****
> The parcels dataset has about 10000 records.  What would you recommend
> changing the memory settings too?****
> Mike****
> *Mike Neimeyer
> **GIS Project Manager*****
> (M) 612.695.7325
> mike.neimeyer at flatrockgeo.com <mike at gisrangers.com>*****
> On Thu, Mar 29, 2012 at 9:22 AM, Dan Little <danlittle at yahoo.com> wrote:**
> I've usually changed the PHP memory settings, not sure where else to look
> on that one.  ****
> Is this parcel file particularly large or complex?****
> *From:* Michael Neimeyer <mike.neimeyer at flatrockgeo.com>
> *To:* geomoose-users at lists.osgeo.org
> *Sent:* Wednesday, March 28, 2012 11:26 AM
> *Subject:* [Geomoose-users] PHP error****
> I am getting a fatal error when running a URL call
> (call=search_by_pin&qstring=243024230015) in GeoMoose.  It was working well
> but now times out:
> *Fatal error*: Allowed memory size of 134217728 bytes exhausted (tried to
> allocate 5 bytes) in *C:\ms4w\apps\geomoose2\htdocs\php\query.php* on
> line *331*
> I tried making changes to the settings in the Apache php.ini file to no
> avail.  Any thoughts on this issue?
> Thanks!
> Mike
> *Mike Neimeyer
> (M) 612.695.7325
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20120329/2c7e9d37/attachment.html
More information about the Geomoose-users mailing list
