[Geomoose-users] Re: printing in geomoose
Brent Fraser bfraser at geoanalytic.com
Sat May 12 19:36:47 EDT 2012
The line you are referring to is (around) line 151 in print_util.php:
//LK To allow use of AGG in onscreen and set to GD for print
$url=$url.'&map_IMAGETYPE=print';
I'm not sure I'd call it a bug, but it is an un-documented feature.  It
expects something like
OUTPUTFORMAT
   NAME  "print"
   DRIVER  GD/GIF
   MIMETYPE  "image/gif"
   IMAGEMODE  PC256
   EXTENSION  "gif"
END
to be in your geomoose_globals.map
Best Regards,
Brent Fraser
On 5/12/2012 4:44 PM, Radoslav Melicher wrote:
> I am using geomoose 2.4 and mapserver 6.0.2 on ubuntu 10.04...
> Thx
> Best Regards
> Radoslav Melicher
> ----- Original Message -----
> From: Brent Fraser<bfraser at geoanalytic.com>
> To: Radoslav Melicher<melicherr at kolektory.cz>
> Sent: Sat, 12 May 2012 15:13:42 +0200 (CEST)
> Subject: Re: printing in geomoose
> Which version of GeoMoose are you using?  Which version of Mapserver?
> And the mailing list has been changed to a new server :  GeoMOOSE Users
> List<geomoose-users at lists.osgeo.org>
> Best Regards,
> Brent Fraser
> On 5/11/2012 8:21 AM, Radoslav Melicher wrote:
>> Hi, Brent.
>> Sorry, for making a stupid mistake. I changed that when I realize that the originally used server went down. Now, I can see the layer when I select it, but when printing, it throws errors mentioned before.
>> I tried to change the print_util.php file (cannot remmeber line) where there is IMAGETYPE (there's only one I think) and changed print for something else, i. e. sprint, and then the error messages changed acoording to change. But now I don't know why is the error occuring, because I haven't changed print_util.php before. And when I tried to comment that line with IMAGETYPE=print in print_util.php it throws exactly same errors as I experience when trying to print layers from geoserver. You can see them here:
>> http://osgeo-org.1560.n6.nabble.com/printing-in-geomoose-td4684481.html
>> In that time I thought there is problem in comunication between geomoose and geoserver, but now, when I commented that line out, it is the same with the mapserver. So, maybe I just need to solve this problem and I will be at good point.
>> Thanks very much indeed for your help
>> Best Regards,
>> Radoslav Melicher
>> From: "Brent Fraser"<bfraser at geoanalytic.com>
>> To: "Radoslav Melicher"<melicherr at kolektory.cz>
>> Sent: Thursday, May 10, 2012 4:59:55 PM
>> A likely cause is that the Tiles At Home () server is no longer
>> available.  I now use MapQuest's OSM tiles
>> (http://wiki.openstreetmap.org/wiki/MapQuest)
>> So in your XML file, replace
>> http://tah.openstreetmap.org/Tiles/tile/${z}/${x}/${y}.png
>> with:
>> http://otile1.mqcdn.com/tiles/1.0.0/osm/${z}/${x}/${y}.jpg
>> Best Regards,
>> Brent Fraser
>> On 5/10/2012 6:45 AM, Radoslav Melicher wrote:
>>> Hi, Brent.
>>> Excuse me for disturbing you, but I am unable to write a new topic to geomoose users forum.
>>> Couple of months ago, you sent me some files to use for printing the OSM tiles. Many thanks again. Since that time I was coping another projects and stuff. Now I got back to it. As you, probably, remember I had a problem with printing in geomoose using geoserver. It still is there, but now I tried a new approach, I set up mapserver and make it work. It looks like it is okey now.
>>> But I still have problem with printing in geomoose, even using only the attached files server through mapserver.
>>> In ms_error.txt on my server I have errors saying:
>>> [Thu May 10 14:20:08 2012].129895 msPostMapParseOutputFormatSetup(): General error message. Unable to select IMAGETYPE `print'.
>>> [Thu May 10 14:20:08 2012].367570 msPostMapParseOutputFormatSetup(): General error message. Unable to select IMAGETYPE `print'.
>>> Each time I try to print OSM_TAH.map there are these two lines again and again and I can see only blank PDF, jpeg or html. I don't know why there are 2 same errors. And I cannot figure out why there is IMAGETYPE 'print'. I tried to use firebug, but for printing it's useless, there is nothing.
>>> I have also tried this manual http://trac.osgeo.org/mapserver/wiki/RenderingOsmDataUbuntu. It throws the same errors each time I try to print the layer and the PDF, jpeg and html files are all blank. I can see these layers when I turn them on in geomoose, but when I print them these errors occur.
>>> And I have another (probably) stupid question. When I am using anyone of these two layers and I am moving the view or zoom level, they are acting weird, because when I zoom, usually I can see just a piece of zoomed area, or when I move the map to whichever side it usually return back where it was before moving or move  in the other direction...
>>> Excuse me once more, I know you all have a lot of work. If it is possible, can you at least help me to be able to write a new topic in the geomoose users forum?
>>> Many many thanks
>>> Best Regards
>>> Radoslav Melicher
>>> To: melicherr at kolektory.cz
>>> Sent: Monday, December 19, 2011 4:58:16 PM
>>> see attached files...
>>> Best Regards,
>>> Brent Fraser
>>> On 12/19/2011 8:55 AM, melicherr at kolektory.cz wrote:
>>>> Hi there. You replied to my post about problems with printing. I have hardly ever used a map file, so what you are suggesting here (http://www.osgeo.org/pipermail/geomoose-users/2010-July/002435.html) is a little bit problematic for me. I tried to write a map file with layer of openstreetmap tiles. I wanted to use it as a base layer with possibility to print. But i wasn't successful.
>>>> Can you send me a map file or some template how it looks like for this purpose?
>>>> thank you very much
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20120512/ad9cf410/attachment.html
More information about the Geomoose-users mailing list
