[Geomoose-users] Fade/unfade controls on by default?
Bistrais, Bob Bob.Bistrais at maine.gov
Tue May 29 10:18:06 PDT 2012
No caching as far as I’m aware.  I did have the layer settings for legend on, but when I removed that, the legend did not show even though the configuration-level parameter was set to show the legend.  And no joy with the fade controls.
But, I’m not going to put too much time into it.  I’m already dabbling with our 2.6 release candidate, and the fade/legend controls act as expected there.
Sent: Tuesday, May 29, 2012 12:45 PM
To: Bistrais, Bob; geomoose-users at lists.osgeo.org
Subject: Re: [Geomoose-users] Fade/unfade controls on by default?
The setting on the individual layer will over-ride it.  Those setting should work.  I don't have a test instance but the code looks correct.  Are you sure there's no caching going on?
	To: geomoose-users at lists.osgeo.org
	Sent: Tuesday, May 29, 2012 9:54 AM
	Hmm, I tried that, but no effect.  What’s more, as an experiment, I set layer_controls.legend.on to false, but the legends still show.  So something must be overriding these parameters?
	Sent: Sunday, May 27, 2012 9:09 AM
	Yep, in the <configuration> section add:
	<param name="layer_controls.fade.on">true</param>
	<param name="layer_controls.unfade.on">true</param>
		Sent: Friday, May 25, 2012 9:17 AM
		Subject: [Geomoose-users] Fade/unfade controls on by default?
		Is it possible to have the layer’s fade and unfade controls visible by default?  I know we can have legend data visible by setting show-legend=”true”.  But a user still needs to click the layer name to display the fade/unfade controls.  Can we have these display automatically, and if so, how?  GeoMoose 2.2, Oregon variant.
		Thanks,
		BB
		Geomoose-users mailing list
		Geomoose-users at lists.osgeo.org
		http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20120529/f63bdc6b/attachment.html>
More information about the Geomoose-users mailing list
