[Geomoose-users] multiple applications from same GeoMoose code
Chris Reudenbach
reudenbach at gmx.org
Fri Nov 30 09:17:06 PST 2012
du to the fact that I want to deliver user specific interactive analysis
results on a daily base (local avalanche risk calculations) with
geomoose I have build a very straightforward workaround:
1) ask user to register (alias)
2) generate for the specific session a user_SessionID of the type (as
an example: pan271112_107111_472245)
3) using the user_SessionID a python based analysis script is running on
the server (dealing with the calculations etc.) that finally generates
<user_SessionID_geomoose.html> <user_SessionID_settings.ini> and
<userIDmapbook.xml> and redirects the corresponding user to his
"personal" geomoose session
I know about the conceptual, security and performance shortcomings - but
nevertheless it works....
At least for this kind of use cases I would really appreciate the
integration of personalized sessions. If possible I would also
contribute in any way...
best regards Chris
Am 30.11.2012 17:39, schrieb Bistrais, Bob:
> Regarding the authentication- some thought, no action. But I see a
> need in future projects to have some authentication.
> *From:*geomoose-users-bounces at lists.osgeo.org
> [mailto:geomoose-users-bounces at lists.osgeo.org] *On Behalf Of *Brian
> Fischer
> *Sent:* Friday, November 30, 2012 11:38 AM
> *To:* geomoose-users at lists.osgeo.org
> *Subject:* [Geomoose-users] multiple applications from same GeoMoose code
> I was just curious if anyone else has thought about or tried any other
> methods to use multiple mapbooks and settings.ini files with one
> GeoMoose code folder.
> In the past I have used this method and it works well.
> http://www.geomoose.org/wiki/index.php/Modification_to_Use_Multiple_Map_Books
> With GeoMoose 2.6 there is another file that is introduced for
> local_settings.ini.
> Also is anyone working on some type of authentication module for
> GeoMoose. Basically what I'm thinking is depending on who you login
> as it would configure the catalog differently.
> Just wanted to get a thread started if anyone else has worked on this
> or thinking about it.
> *Brian Fischer, CFM*
> Principal | GIS Project Manager
> *O*763.493.4522 | *D* 763.493.6664 | *M* 763.229.2734
> cid:image001.jpg at 01CC3702.356B79C0
> 6901 E Fish Lake Rd. , Suite 140 . Maple Grove, MN . 55369
> *www.houstoneng.com* <http://www.houstoneng.com/>**
> This entire message (including all forwards and replies) and any
> attachments are for the sole use of the intended recipient(s) and may
> contain proprietary, confidential, trade secret, work-product,
> attorney-client or privileged information. Any unauthorized review,
> use, disclosure or distribution is prohibited and may be a violation
> of law. If you are not the intended recipient, please contact the
> sender by reply email and destroy all copies of the original message.
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
Dr Christoph Reudenbach, Philipps-University of Marburg, Faculty of Geography, GIS and Environmental Modeling, Deutschhausstr. 10, D-35032 Marburg, fon: ++49.(0)6421.2824296, fax: ++49.(0)6421.2828950
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20121130/46c18cd8/attachment-0001.html>
Name: not available
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20121130/46c18cd8/attachment-0001.jpe>
More information about the Geomoose-users
