[Geomoose-users] Opacity in Geomoose 2.6
Matej Mailing mailing at tam.si
Mon Oct 15 10:12:48 PDT 2012
I have overwritten geomoose directory (containing js files) and php
directory on my test server and it doesn't work.
Which files do I have to get from the trunk - where is the parser
located? I know it's always the best to use the complete package
especially if there are major version differences.
Thanks,
Matej
2012/10/15 Brian Fischer <bfischer at houstoneng.com>:
> This was fixed but is only in trunk SVN right now.  http://trac.osgeo.org/geomoose/ticket/127
> Brian Fischer, CFM
> Principal | GIS Project Manager
> Houston Engineering, Inc.
> O 763.493.4522 | D 763.493.6664 | M 763.229.2734
> -----Original Message-----
> From: geomoose-users-bounces at lists.osgeo.org [mailto:geomoose-users-bounces at lists.osgeo.org] On Behalf Of Matej Mailing
> Sent: Monday, October 15, 2012 6:01 AM
> To: Dan Little
> Cc: Scott Wolfert; geomoose-users at lists.osgeo.org
> Subject: Re: [Geomoose-users] Opacity in Geomoose 2.6
> Hi,
> is the situation with the opacity attribute for mapsource different than it was in July?
> I have the same problem as described below.
> Thanks,
> Matej
> 2012/7/20 Dan Little <danlittle at yahoo.com>:
>> Hi Scott,
>> I just went through the 2.6 code and it looks like that got missed in
>> testing.  We'll need to add it back in.  The entire API is there and
>> the code but just not the parser to recognize the option.
>> Any chance you'd be willing to write a quick ticket in our Trac?  (
>> http://trac.osgeo.org/geomoose/ )
>> Thanks!
>> ________________________________
>> From: Scott Wolfert <swolfert at houstoneng.com>
>> To: "'geomoose-users at lists.osgeo.org'"
>> <geomoose-users at lists.osgeo.org>
>> Sent: Friday, July 20, 2012 8:37 AM
>> Subject: [Geomoose-users] Opacity in Geomoose 2.6
>> Hello,
>> I am wondering if anything has changed within the mapbook for opacity
>> settings in Geomoose 2.6? I currently have it setup to be something
>> like the following, however it is not working properly.
>> <map-source name="Divisions" type="mapserver" opacity="0.5">
>>                                 <file>./data/Divisions.map</file>
>>                                 <layer name="Divisions" status="on" />
>> </map-source>
>> Has anyone had any luck with this in 2.6?
>> Thanks for your help.
>> Scott
>> Geomoose-users mailing list
>> Geomoose-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users mailing list
