[Geomoose-users] Identify not working
Matej Mailing mailing at tam.si
Wed Sep 19 12:42:13 PDT 2012
Hi all,
I was able to get parcels identification working, but my layer still
doesn't work. When enabling debug messages in identify.php, I get the
followint output:
"Notice: Undefined index: wms_header in /path/php/identify.php on line 116
Warning: file(): Filename cannot be empty in /path/php/identify.php on line 116
Warning: implode(): Invalid arguments passed in /path/php/identify.php
on line 116
Notice: Undefined index: wms_record in /path/php/identify.php on line 117
Warning: file(): Filename cannot be empty in /path/php/identify.php on line 117
on line 117
Notice: Undefined index: wms_footer in /path/php/identify.php on line 118
Warning: file(): Filename cannot be empty in /path/php/identify.php on line 118
on line 118
Warning: mapObj::queryByPoint(): [MapServer Error]: msQueryByPoint():
No matching record(s) found.
 in /path/php/identify.php on line 170"
When turning off the debug mode, I get the same output as mentioned
before: just coordinates of the point.
Thanks for any ideas,
Matej
2012/9/13 Eli Adam <eadam at co.lincoln.or.us>:
> On Wed, Sep 12, 2012 at 4:24 PM, Matej Mailing <mailing at tam.si> wrote:
>> Hi,
>> I have followed all 3 points, but with no success. I still get the
>> coordinates and that's it ...
> If you started with the demo, does identify on the parcels work?
>> Now I have removed all the fields from the template file (that begins
>> with the <!-- MapServer Template -->) so it only outputs some "hello
>> world text", but it still doesn't work. I have now found a
>> metadata="true" option available when defining the layer in the
>> mapbook file, but also with this set to true it doesn't work. I have
>> also added only this layer to be used for identify via <input
>> type="hidden" name="layers" value="..."/> with no result :/
>> What is the best way to debug this issue?
> Firefox/firebug could be a good way to start.  Using the firebug
> console on the online demo leads to seeing things like:
> post
> dojo.preventCache       1347492736022
> layers  blank%3Ablank/blank%3Aborders%3Aborders/city_labels%3Aborders/county_labels%3Aborders/city_poly%3Aborders/county_borders%3Aparcels%3Aparcels/parcels%3Asketch
> projection      EPSG%3A3857
> shape   POINT%28-10372969.112863%205552707.7829098%29
> Source
> layers=blank%253Ablank%2Fblank%253Aborders%253Aborders%2Fcity_labels%253Aborders%2Fcounty_labels%253Aborders%2Fcity_poly%253Aborders%2Fcounty_borders%253Aparcels%253Aparcels%2Fparcels%253Asketch&projection=EPSG%253A3857&shape=POINT%2528-10372969.112863%25205552707.7829098%2529&dojo.preventCache=1347492736022
> response
> <results><script> GeoMOOSE.clearLayerParameters('highlight');
> GeoMOOSE.turnLayerOff('highlight/highlight');</script><html><![CDATA[<!--
> Detailed information for the area you clicked on the map...
> <table border="0">
> <tr>
> <td colspan="2"><b><u>Ground Coordinates</u></b>
> <br>
> <b>X: </b>485549.182735
> <br>
> <b>Y: </b>4934226.01043</td>
> </tr>
> <tr>
> <td> </td>
> <td> </td>
> </tr>
> </table>
> <table border="0" cellpadding="1" cellspacing="2">
> <tr bgcolor="#DEE5EB"><td colspan="2"><b><u>Parcels</u></b></tr>
> <tr>
> <td align="right"><b>PIN:</b></td>
> <td>130260001175 <a
> href="javascript:GeoMOOSE.startService('feature_report', {'PIN' :
> '130260001175', 'src' : 'parcels/parcels'})">Report</a></td>
> </tr>
> <tr>
> <td align="right"><b>Owner Name:</b></td>
> <td>Thaddeus Garcia</td>
> </tr>
> <tr>
> <td align="right"><b>Est. Market Value:</b></td>
> <td>1178700</td>
> </tr>
> <tr>
> <td align="right"><b>Acres:</b></td>
> <td>154.37</td>
> </tr>
> <tr>
> <td> </td>
> <td> </td>
> </tr>
> ]]></html><footer><![CDATA[<b>Disclaimer: This information is being
> distributed as demonstation data only.  You should not use the data
> for any other purposes.</b>
> ]]></footer></results>
> You can do the same with your site and see exactly what is coming back
> in the response.  Posting more specific details (relevant parts of
> mapbook.xml, ogrinfo of datasource) or providing a link to your
> website might make it easier for people to make suggestions.  Getting
> the parcels example working correctly and then closely matching the
> parcels set can be a starting place.  Also confirm that relative paths
> are correct.
> Best Regards, Eli
>> Thanks for any ideas in advance ....
>> Matej
>>> Matej,
>>> On Wed, Sep 12, 2012 at 3:52 PM, Matej Mailing <mailing at tam.si> wrote:
>>>> Hi,
>>>> I have a layer where I have added
>>>>                METADATA
>>>>                        'identify_record'       'templates/identify.html'
>>>>                END
>>>> and created a file in the subdirectory of the directory where the map
>>>> file is. Identify service is active since when I click to some point I
>>> Does your template start with:
>>>> get the coordinates. This layer can be the only layer turned on in the
>>>> Catalog, but I still get no identify results and the message
>>>> containing the coordinates seems to be used.
>>> Can you review this draft updated documentation and see if it helps?
>>> http://geomoose.org/trunk/howto/identify.html
>>> HTH, Eli
>>>> What am I doing wrong? I have been pulling my hair out for quite some
>>>> hours now ...
>>>> Thanks for all the ideas.
>>>> Matej
>>>> _______________________________________________
>>>> Geomoose-users mailing list
>>>> Geomoose-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users mailing list
