[Geomoose-users] Identify not working
Matej Mailing mailing at tam.si
Wed Sep 19 13:42:04 PDT 2012
the issue with not-passed projection is solved - it seems I have
removed input type="projection" from the identify service by mistake.
Now when turning on the debug mode for identify.map I get no more
errors and warnings, just this one:
"Warning: mapObj::queryByPoint(): [MapServer Error]: msQueryByPoint():
No matching record(s) found.
 in /var/www/elgismap/php/identify.php on line 170"
When turning debug off, I get no results.
Map file:
MAP NAME my_layer
        DEBUG 5
        EXTENT 484000 90000 620000 190000
        STATUS ON
        SIZE 2000 2000
        TRANSPARENT TRUE
        UNITS METERS
        IMAGECOLOR 255 255 255
        IMAGETYPE PNG
        INCLUDE "../globals.map"
        PROJECTION
                "init=epsg:4326"
        END
        QUERYMAP
                STATUS ON
                STYLE SELECTED
        END
        WEB
                METADATA
                        "wms_title"             "my_layer"
                        "wms_srs"               "EPSG:4326"
                        "wms_enable_request"    "*"
                END
                QUERYFORMAT "text/xml"
                INCLUDE "../temp_directory.map"
                IMAGEPATH "/var/www/gm/tmp/"
                IMAGEURL "/gm/tmp/"
        END
        LEGEND
              STATUS ON
              LABEL
                TYPE TRUETYPE
                FONT vera_sans
                SIZE 8
                COLOR 0 0 0
              END
        END
        LAYER
                NAME "layer_name"
                TYPE POINT
                STATUS DEFAULT
                CONNECTIONTYPE POSTGIS
                CONNECTION "host=localhost ... port=5432 options='-c
client_encoding=UTF8'"
                DATA "wkb_geometry from table"
                CLASS
                        TEXT '[text]'
                        COLOR 200 23 255
                        SYMBOL 'circle'
                        MAXSIZE 13
                        MINSIZE 10
                        LABEL
                                TYPE TRUETYPE
                                OFFSET 2 2
                                FONT timesi
                                POSITION ur
                                ANTIALIAS true
                                MINSIZE 12
                                MAXSIZE 15
                                COLOR 10 120 80
                        END
               END
               METADATA
                       'identify_record'       'templates/identify.html'
               END
               TOLERANCE 0
        END
END
Thanks,
Matej
2012/9/19 Anderson, Dean <anderson.dean at co.polk.or.us>:
> So - what does your map file look like?
> THanks
> Dean
> On Wed, Sep 19, 2012 at 1:20 PM, Matej Mailing <mailing at tam.si> wrote:
>> Hi,
>> wms_* entries were commented out (non-wms_* were not), but also after
>> uncommenting them the situation is the same. When checking the POST
>> parameters for identify.php with Firebug, there is no projection. The
>> projection file (Javascript) is successfully loaded on the site and
>> the EPSG:4326 is set both in mapbook.xml and settings.ini (in [map]
>> section).
>> The parcels demo has data stored in SHP and we are using PostGIS for
>> it. I have gone through both map files and the only difference is that
>> in the WEB METADATA of our mapfile we have wms_title, wms_srs and
>> wms_enable_request and in parcels mapfile there are ows_* tags ...
>> Thanks,
>> Matej
>> 2012/9/19 Brent Fraser <bfraser at geoanalytic.com>:
>> > Does your settings.ini file have entries like
>> > [identify]
>> > identify_header=identify/header.html
>> > identify_footer=identify/footer.html
>> > wms_header=identify/wms_header.html
>> > wms_record=identify/wms_record.html
>> > wms_footer=identify/wms_footer.html
>> > and do the files pointed to by the wms_* entries exist in the htdocs\php
>> > folder?
>> > Best Regards,
>> > Brent Fraser
>> > On 9/19/2012 1:47 PM, Matej Mailing wrote:
>> >> Just now I have found out that in my case I have no "projection"
>> >> parameter sent into the identify.php when comparing to the working
>> >> parcels sample. We are using EPSG:4326 - could this be a problem?
>> >> Thanks,
>> >> Matej
>> >> 2012/9/19 Matej Mailing <mailing at tam.si>:
>> >>> Hi all,
>> >>> I was able to get parcels identification working, but my layer still
>> >>> doesn't work. When enabling debug messages in identify.php, I get the
>> >>> followint output:
>> >>> "Notice: Undefined index: wms_header in /path/php/identify.php on line
>> >>> 116
>> >>> Warning: file(): Filename cannot be empty in /path/php/identify.php on
>> >>> line 116
>> >>> Warning: implode(): Invalid arguments passed in /path/php/identify.php
>> >>> on line 116
>> >>> Notice: Undefined index: wms_record in /path/php/identify.php on line
>> >>> 117
>> >>> line 117
>> >>> on line 117
>> >>> Notice: Undefined index: wms_footer in /path/php/identify.php on line
>> >>> 118
>> >>> line 118
>> >>> on line 118
>> >>>   in /path/php/identify.php on line 170"
>> >>> When turning off the debug mode, I get the same output as mentioned
>> >>> before: just coordinates of the point.
>> >>> Thanks for any ideas,
>> >>> Matej
>> >>> 2012/9/13 Eli Adam <eadam at co.lincoln.or.us>:
>> >>>> On Wed, Sep 12, 2012 at 4:24 PM, Matej Mailing <mailing at tam.si>
>> >>>> wrote:
>> >>>>> Hi,
>> >>>>> I have followed all 3 points, but with no success. I still get the
>> >>>>> coordinates and that's it ...
>> >>>> If you started with the demo, does identify on the parcels work?
>> >>>>> Now I have removed all the fields from the template file (that
>> >>>>> begins
>> >>>>> with the <!-- MapServer Template -->) so it only outputs some "hello
>> >>>>> world text", but it still doesn't work. I have now found a
>> >>>>> metadata="true" option available when defining the layer in the
>> >>>>> mapbook file, but also with this set to true it doesn't work. I have
>> >>>>> also added only this layer to be used for identify via <input
>> >>>>> type="hidden" name="layers" value="..."/> with no result :/
>> >>>>> What is the best way to debug this issue?
>> >>>> Firefox/firebug could be a good way to start.  Using the firebug
>> >>>> console on the online demo leads to seeing things like:
>> >>>> post
>> >>>> dojo.preventCache       1347492736022
>> >>>> layers
>> >>>> blank%3Ablank/blank%3Aborders%3Aborders/city_labels%3Aborders/county_labels%3Aborders/city_poly%3Aborders/county_borders%3Aparcels%3Aparcels/parcels%3Asketch
>> >>>> projection      EPSG%3A3857
>> >>>> shape   POINT%28-10372969.112863%205552707.7829098%29
>> >>>> Source
>> >>>> layers=blank%253Ablank%2Fblank%253Aborders%253Aborders%2Fcity_labels%253Aborders%2Fcounty_labels%253Aborders%2Fcity_poly%253Aborders%2Fcounty_borders%253Aparcels%253Aparcels%2Fparcels%253Asketch&projection=EPSG%253A3857&shape=POINT%2528-10372969.112863%25205552707.7829098%2529&dojo.preventCache=1347492736022
>> >>>> response
>> >>>> <results><script> GeoMOOSE.clearLayerParameters('highlight');
>> >>>> GeoMOOSE.turnLayerOff('highlight/highlight');</script><html><![CDATA[<!--
>> >>>> Detailed information for the area you clicked on the map...
>> >>>> <table border="0">
>> >>>> <tr>
>> >>>> <td colspan="2"><b><u>Ground Coordinates</u></b>
>> >>>> <br>
>> >>>> <b>X: </b>485549.182735
>> >>>> <br>
>> >>>> <b>Y: </b>4934226.01043</td>
>> >>>> </tr>
>> >>>> <tr>
>> >>>> <td> </td>
>> >>>> <td> </td>
>> >>>> </tr>
>> >>>> </table>
>> >>>> <table border="0" cellpadding="1" cellspacing="2">
>> >>>> <tr bgcolor="#DEE5EB"><td colspan="2"><b><u>Parcels</u></b></tr>
>> >>>> <tr>
>> >>>> <td align="right"><b>PIN:</b></td>
>> >>>> <td>130260001175 <a
>> >>>> href="javascript:GeoMOOSE.startService('feature_report', {'PIN' :
>> >>>> '130260001175', 'src' : 'parcels/parcels'})">Report</a></td>
>> >>>> </tr>
>> >>>> <tr>
>> >>>> <td align="right"><b>Owner Name:</b></td>
>> >>>> <td>Thaddeus Garcia</td>
>> >>>> </tr>
>> >>>> <tr>
>> >>>> <td align="right"><b>Est. Market Value:</b></td>
>> >>>> <td>1178700</td>
>> >>>> </tr>
>> >>>> <tr>
>> >>>> <td align="right"><b>Acres:</b></td>
>> >>>> <td>154.37</td>
>> >>>> </tr>
>> >>>> <tr>
>> >>>> <td> </td>
>> >>>> <td> </td>
>> >>>> </tr>
>> >>>> ]]></html><footer><![CDATA[<b>Disclaimer: This information is being
>> >>>> distributed as demonstation data only.  You should not use the data
>> >>>> for any other purposes.</b>
>> >>>> ]]></footer></results>
>> >>>> You can do the same with your site and see exactly what is coming
>> >>>> back
>> >>>> in the response.  Posting more specific details (relevant parts of
>> >>>> mapbook.xml, ogrinfo of datasource) or providing a link to your
>> >>>> website might make it easier for people to make suggestions.  Getting
>> >>>> the parcels example working correctly and then closely matching the
>> >>>> parcels set can be a starting place.  Also confirm that relative
>> >>>> paths
>> >>>> are correct.
>> >>>> Best Regards, Eli
>> >>>>> Thanks for any ideas in advance ....
>> >>>>> Matej
>> >>>>>> Matej,
>> >>>>>> On Wed, Sep 12, 2012 at 3:52 PM, Matej Mailing <mailing at tam.si>
>> >>>>>> wrote:
>> >>>>>>> Hi,
>> >>>>>>> I have a layer where I have added
>> >>>>>>>                 METADATA
>> >>>>>>>                         'identify_record'
>> >>>>>>>                 END
>> >>>>>>> and created a file in the subdirectory of the directory where the
>> >>>>>>> map
>> >>>>>>> file is. Identify service is active since when I click to some
>> >>>>>>> point
>> >>>>>>> I
>> >>>>>> Does your template start with:
>> >>>>>>> get the coordinates. This layer can be the only layer turned on in
>> >>>>>>> the
>> >>>>>>> Catalog, but I still get no identify results and the message
>> >>>>>>> containing the coordinates seems to be used.
>> >>>>>> Can you review this draft updated documentation and see if it
>> >>>>>> helps?
>> >>>>>> http://geomoose.org/trunk/howto/identify.html
>> >>>>>> HTH, Eli
>> >>>>>>> What am I doing wrong? I have been pulling my hair out for quite
>> >>>>>>> some
>> >>>>>>> hours now ...
>> >>>>>>> Thanks for all the ideas.
>> >>>>>>> Matej
>> >>>>>>> _______________________________________________
>> >>>>>>> Geomoose-users mailing list
>> >>>>>>> Geomoose-users at lists.osgeo.org
>> >>>>>>> http://lists.osgeo.org/mailman/listinfo/geomoose-users
> Dean R Anderson
> IT Director
> Polk County
More information about the Geomoose-users mailing list
